toshiba satellite pro L550-17M NSWAA LA-5322P
  • krimo
    • Sep 2017
    • 81
    • algeria
    toshiba satellite pro L550-17M NSWAA LA-5322P REV:1.0
    4096KO
    256KO
    this laptop had a problem code bios I tried to flash the bios and I saved old bios the new bios did not succeed so I handed old bios I had a display problem I changed the two eprom same problem i change the cpu and rams same problem
    i need help please
    THANK YOU
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: toshiba satellite pro L550-17M NSWAA LA-5322P
    upload the original backup Bios here to check.
    Do you mean: firstly, the original Bios worked, but after the programming, the original Bios does not work? is this right?
    • krimo
      • Sep 2017
      • 81
      • algeria
      yes caspian
      • krimo
        • Sep 2017
        • 81
        • algeria
        thank you caspian
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          does the HDD spin? how is the fan's speed? is there any blinking or any other symptoms?
          • krimo
            • Sep 2017
            • 81
            • algeria
            old bios
            • krimo
              • Sep 2017
              • 81
              • algeria
              the client took the hard drive the fan runs normal but after some second stops but when i put another flash bios the fan runs with a more temp no blinking
              • krimo
                • Sep 2017
                • 81
                • algeria
                can you help me
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  There are a number of technicians in this forum who solve Bios problems better. They will help you.
                  have you verified the Bios chip's content after the programming? Maybe, you need to use a new Bios dump that other technicians upload here for you.
                  To get better help, explain the results of any test that you have done so far.
                  • krimo
                    • Sep 2017
                    • 81
                    • algeria
                    thank you
                      • 21145
                      Try this bios,its straight from toshiba.You can rule out a bios problem if it doesn`t work.
                      • krimo
                        • Sep 2017
                        • 81
                        • algeria
                        thank you i will try
                        • krimo
                          • Sep 2017
                          • 81
                          • algeria
                          hi dasn't work i dont know where is the problem
                          can you help me
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            To get better help, explain the results of any tests that you have done so far. how was the fan using the new Bios dump?
                            • krimo
                              • Sep 2017
                              • 81
                              • algeria
                              the fan turn normaly
                              • krimo
                                • Sep 2017
                                • 81
                                • algeria
                                can you help me
                                • caspian
                                  • Oct 2015
                                  • 1591
                                  • Laptop
                                  do the CPU and the GPU get warm?
                                  • krimo
                                    • Sep 2017
                                    • 81
                                    • algeria
                                    no
                                    • krimo
                                      • Sep 2017
                                      • 81
                                      • algeria
                                      can you help me
                                      • caspian
                                        • Oct 2015
                                        • 1591
                                        • Laptop
                                        does the PCH get warm? then, check which voltage rails are missing.
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:10 PM
