HP ProBook 2560p missing info
  • Behemot
    • 4845
    • CZ
    I got this laptop with the usual crap about missing BIOS info. Not sure if it was BIOS reflashed, or MoBo replaced, but I tried everything possible and could not make it work to input the values. BIOS info shows the UUID to be all Fs which should be what I want. Wnbdmifit 1.19 craps me with locked MPM. Version 2.07, 2.10 and 2.13 crap me with not supporting this system board.
    When I put it on bootable drive, it boots, wants me to input date, no matter whan I input it tells me I need to fill serial number first to run more options and gives me options to program, show, save or blank UUID. No matter what I do, either nothing happens, or it shows UUID as 0x0000000…all zeroes, the other fields are blak and than halts.
    Tried several different SMC.bin files to try to blank the UUID, nothing ever happens.
    So, is there a way out of this? The laptop works, just shows this crap everytime it POSTs.
  • khaahk
    • Dec 2013
    • 786
    • Estonia
    Re: HP ProBook 2560p missing info
    The easiest way is to find working dump, there are some in this forum, the sn won't be correct but it will boot without error messages.
    • Behemot
      • 4845
      • CZ
      So it is really just about the BIOS itself? Cause I've read that normal flashing does not touch the UUID. Wouldn't it complain with it either being all zeroes or Fs?
        • 21231
        Try this hp toolkit,it has support for the 2560p
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          Edit this file original bios using hex editor.
          • Behemot
            • 4845
            • CZ
            Guess that this is the part:
            H P _ M O D E L H P E l i t e B o o k 2 5 6 0 p mŞU   C wwÝÇeŢ/ŠeEfB¦U9ěH P _ C S N C N U 2 1 4 1 D 8 C “ŞU   % x3Çe/*eEfB¦U9ěH P _ S K U  X B 2 0 8 A V ŞU    xÝÇe/*eEfB¦U9ěH P _ U U I D UĐE^ŐCâŚâ/ XŞU   •m͉]ziL–`΁l FH P _ D i g i t a l E s t a r  ŞU   , JČôjü˙“K»ŕ ftďH P _ N V S T R I N G S A 0 0 0 1 D 0 2 P C E Y A 0 0 1 Y 2 J 2 I 4
            • Behemot
              • 4845
              • CZ
              Tried this. It does start doing something, unlike the other versions, so when I input P, it asks for PN, SN and than ConfigID where I am screwed. After inputing some zeroes it finally gaves up with this error:
              Failed to write ConfigID (Error Code: 0x85). The system has to be on MPM mode to use this command
              Than it asks for CT number, after filling which it displays current status (nothing filled) and hangs.
              Seems that I do need to unlock the BIOS after all? And what the heck is the ConfigID?
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                You try my file?
                • Behemot
                  • 4845
                  • CZ
                  What exactly is that part of? Should I save it as SMC.bin after modding the few strings and try to unlock the MPM?
                    • 21231
                    Look inside the battery compartment at the stickers,and on the base, there you`ll find your serial number etc. The UUID number might be on a sticker on the RAM slot . Can you upload a bios backup ,and let us have those numbers,or pm them to one of us.
                    e.g.
                    HP CSN xxxxxxx
                    HP SKU xxxxxxxx
                    SYSTEM BOARD CT xxx etc
                    Mac Address xxxxxxx
                    UUID xxx etc
                    • Behemot
                      • 4845
                      • CZ
                      I got PN, SN, MB CTU, MAC.
                      It does not want MAC on me anyways, but it wants some ConfigID. Ther is no UUID anywhere either.
                        • 21231
                        You can enter the number 1 for the UUID. MAC you can enter randomly.
                        "Failed to write ConfigID (Error Code: 0x85). The system has to be on MPM mode to use this command"
                        I can sort that out if you have a bios backup, i can edit the bios with an unlocked mpm ,then you can use the dmi toolkit again to enter your SN etc.
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          My file all have information but different sn,ctu,and other.You need old bios and edit this file if have bios programmer.
                          • Behemot
                            • 4845
                            • CZ
                            IC. What tool can I use to dump or write BIOS image with these 2560p?
                              • 21231
                              Download the file in the attatchment and save it.Extract the folder and save the FPT folder to your C drive
                              C:\FPT64
                              Shut down the laptop.Hold down the Win key and the up and down arrow keys ,start the laptop keep holding the keys for a few seconds. You should see a message at the top left saying flash descriptor unlocked, let go of the keys and let windows boot up.Open a command prompt as admin ,type each command and press enter after each.
                              cd C:\FPT64
                              fptw64 -D backup.rom
                              exit
                              Shut down the laptop,take the charger and battery out,press the power button for 20 seconds.Put the battery back in,plug charger in and start laptop.
                              You should have a bios backup now in the C:\FPT64 folder called backup.rom .Zip that file up and upload it.
                              • Behemot
                                • 4845
                                • CZ
                                Well it did not unlock (no message during startup other than the leftover* after messing with the DMI unlock tool) so I am getting error (no read access).
                                Does the C:\ have to be the first partition on the hard drive? Isn't it better to use flash drive instead?
                                __________
                                *Manufacturing Program Mode Set: 0 of 10
                                  • 21231
                                  The tool i posted on post #15 is to make a backup of your bios,it can also be used to flash a bios image,but thats not what we want to do yet. Try again this time hold down the WIN + LEFT ARROW + RIGHT ARROW keys and press the start button holding those keys for a few seconds , if theres a message about the flash descriptor being unlocked thats ok,keep following the instructions above, if there isn`t any message you must have a later 2560 with an ivy bridge cpu. If you`ve got an ivy bridge cpu then you`ll have to read the bios with a bios programmer and soic clip, or keep trying with the different DMI tools.
                                  • Stevie2001
                                    • Apr 2018
                                    • 183
                                    • irland
                                    https://youtu.be/9VKwnKrGsl8
                                    • Behemot
                                      • 4845
                                      • CZ
                                      Interesting, using left and right keys changed something, this time it wrote something about SPI and I've got the dump, hold on a sec.
                                      Why the heck do all the manuals say up and down when it's right and left?
                                      ADD// here goes; ya need the filled .vss fila too, or the SN, PN, CTU values?
                                        • 21231
                                        Great. Can you PM the sn ,pn,etc to me and imranromi .
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 07:12 AM
                                          09-07-2024, 06:40 AM
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:50 AM
                                          HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-06-2024, 10:51 AM
