Lenovo g500 bios problem help!
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    I have Lenovo 500g laptop.
    I have 3 and 5 v on corresponded LP but on bios pin 8 I have no voltage.
    I removed bios ic and again no voltage.
    On battery connector I also have 3.3v
    From where can I place jumper to give 3v on bios pin 8!
    I have tried to give from pu39 but I have 3.3v on all pins.
    Pls help
  • krimo
    • Sep 2017
    • 81
    • algeria
    Re: Lenovo g500 bios problem help!
    You have a display or ignition problem
    • krimo
      • Sep 2017
      • 81
      • algeria
      • khaahk
        • Dec 2013
        • 769
        • Estonia
        Most likely bios does not need to be powered before full power on. Look at kbc power and signals. Bios 3v comes on when ec gives enable signal to 3v_rom. Mainboard platform not specified, is it la-9632p?
        KBC has its own internal bios so main bios doesn't need to be powered on at first.
        • NConstantinou
          • May 2017
          • 335
          • Cyprus
          Hi Khaahk and thanks for your reply,
          the motherboard is LA-9632P.
          i know that when connecting power adapter and WITHOUT pressing power button you must have 3 and 5 v on LP's 3,5v, battary connector, KBC controller and BIOS pin 8.
          i checked on KBC , i have EC_VDD/VCC (+3vALW)
          any ideas
          thanks
          • NConstantinou
            • May 2017
            • 335
            • Cyprus
            i will check on KBC if i have EC_VDD/VCC (+3vALW
            • NConstantinou
              • May 2017
              • 335
              • Cyprus
              can you tell me which pin of KBC is enable signal to 3_ROM
              • khaahk
                • Dec 2013
                • 769
                • Estonia
                Pin 107 PCH_PWR_EN. If it stays low then either kbc is dead or needs reprogramming or power button not transfered to kbc. How much current is mainboard using? Does the kbc get hot?
                • NConstantinou
                  • May 2017
                  • 335
                  • Cyprus
                  Dream Khaahk,
                  Pin 107pch_pwd_en stays at 3.3v,using power supply at 5a.
                  Inc does not get had
                  Any other ideas
                  I NOTICED THE CURRENT ON POWER SUPPLY DROPS FROM 0.14 TO 0.01A WHILE LAPTOP IS RUNNING
                  • NConstantinou
                    • May 2017
                    • 335
                    • Cyprus
                    Dream Khaahk,
                    Any other ideas
                    • khaahk
                      • Dec 2013
                      • 769
                      • Estonia
                      On second view of the schematic it shows most of the components on that circuit marked with @ sign, meaning they should not be installed. So i have no idea how the spi rom gets its power. If you have 3V ALW and no spi 3v then something must be swithing or protecting the 3v_rom circuit.
                      What do you mean by amperage drops from 0.14A to 0.01A? After what?
                      Measure resistance from pin 8 of spi rom to gnd. Maybe something is shorted on that line.
                      • NConstantinou
                        • May 2017
                        • 335
                        • Cyprus
                        Dear Khaahk,
                        The resistance of Bios pin 8 is .8K to grd.
                        when laptop is switched on using power supply 19v and ampere is at full 5A the display on power supply shows 0.14A and aftera few seconds drops to 0.01A
                        • khaahk
                          • Dec 2013
                          • 769
                          • Estonia
                          Check if bios is powered during that 2 seconds. Maybe it is read and then powered off to limit power consumption. Then check power button action, lid switch status, communication between EC and PCH.
                          • NConstantinou
                            • May 2017
                            • 335
                            • Cyprus
                            DEAR kHAAHK,
                            i would like to proceed to reprogram ene39012 kbc.
                            i have some questions.
                            wiring is done between RT809F and keyboard connecor and i have also read and save BIOS.
                            if i remember correctly this LA-9632P mobo is using ICH76. Please check it also to confirm.
                            do i need ICH77 bin file! always go one number higher!
                            do you by any chance have this bin file!
                              • 20938
                              You just need to program a KBC dump.
                              • NConstantinou
                                • May 2017
                                • 335
                                • Cyprus
                                Please explain what do you mean by that
                                What to do
                                  • 20938
                                  There is no ICH bin file, you just need to flash/program the bios and EC (kbc)
                                  • NConstantinou
                                    • May 2017
                                    • 335
                                    • Cyprus
                                    Please describe the steps to do that
                                    • khaahk
                                      • Dec 2013
                                      • 769
                                      • Estonia
                                      Use your programmers manual to program kbc.
                                      File attached:
                                      • NConstantinou
                                        • May 2017
                                        • 335
                                        • Cyprus
                                        I will try tomorrow and let you know
                                        • madrali
                                          lenovo e15 gen2 bios ? problem
                                          by madrali
                                          Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                                          20TD-50S0KU00
                                          Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                                          I used Lenovo's SmartBeep decoder and it returned error 0284:
                                          "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                                          I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                                          06-16-2025, 12:06 PM
                                        • MaxonDomkrat
                                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                          by MaxonDomkrat
                                          Hi everyone.
                                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                          07-30-2025, 01:27 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
