Re: HP DMI Tool NBDmiFit
Did you make a backup of the original bios, if so post it in the "Bios Requests" for the pass removing.
Hello everyone, I would like to ask you for help for an Hp Elitebook 8440p, which after a reset procedure of the bios pass no longer gave me the UUID (due to my fault) that during programming I did not enter it correctly. I tried with the various HP DMI, but I could not find the parameter for the UUID change there is only the choice X for the reset or to put a random one. What procedure or right program should I perform? Thank youLeave a comment:
I have an issue with my HP 255 G4. Without having replaced the motherboard i get the following error message:
"Product Information not valid - The Following product information programmed into system board is missing or invalid
System board (00A) Product Name, Product Serial Number, Product Number and System Board CT Number".
When enter the bios i see born up date and factory installed os is missing too. I tried HP BCU and after enter all values and when i typed the command "/SetConfig :"filename" i got an "Access Denied" error. I want to try NBDmiFit but i don' t know which version should work. Can anyone help me, please?
ThanksLeave a comment:
I have a HP Envy Curved All-in-one 34-b010.
Which tool should I using to change the serial number? I replaced the motherboard.Leave a comment:
Hello!
I have HP Elitebook 840 g2, i have "Warning: Machine is not in committed state" on bootup i already collect thoses Infos
Serial Number : 5CG6143X05
Product Number : N9T65UC
Description : HP ELITEBOOK 840 G2 NOTEBOOK PC
IMG_BuildId BID=14WWCSDW602#SABA#DABA
IMG_Desc1 3X47676J6b757H7M7Q7W7s7z9AaBaEawbh.r3
any suggestionLeave a comment:
Product: HP 608 G1
Operating System: Microsoft Windows 10 (64-Bit)
Hi! After installing the modem in the tablet, the BIOS was reset.
Product information is not valid. MPM is blocked.
To unlock it, you need a SMC.bin Tried universal SMS.bin from the NbDmiFix utility from version 2.00 to the latest 2.14.1 I get the error SMC command failure.
I contacted the online support service of HP, I get the answer: Your device is no longer supported.
Please help me generate the SMC.bin
Tablet HP 608 G1, 64 bit,
UUID 785634123412785690ABCDDEEFAABBCC, S/N 5CD7065BXY
Thank you!Leave a comment:
Hello! There is an HP 608 G1 tablet. When loading, it writes: "Manufacture programming mode is in unlock". In the Readme files, it says that you need to use WinPE64 to create a bootable flash drive. Where can I download the file winpe64-2.12.zip? If you use a regular WinPE build, then wndmifit (2.10, 2.12, 2.13, 2.14) does not work. If you use the utility BiosConfigUtility64.exe then writes "System not supported". Please help me find it WinPE64-2.12.zip to create a bootable USB key. ps If you use https://docs.microsoft.com/en-us/win...pe--windows-pe Utilities also do not work. Thanks.Last edited by SKYSPB; 01-31-2021, 01:12 AM.Leave a comment:
Hello! There is an HP 608 G1 tablet. When loading, it writes: "Manufacture programming mode is in unlock". In the Readme files, it says that you need to use WinPE64 to create a bootable flash drive. Where can I download the file winpe64-2.12.zip? If you use a regular WinPE build, then wndmifit (2.10, 2.12, 2.13, 2.14) does not work. If you use the utility BiosConfigUtility64.exe then writes "System not supported". Please help me find it WinPE64-2.12.zip to create a bootable USB key. ps If you use https://docs.microsoft.com/en-us/win...pe--windows-pe Utilities also do not work. Thanks.Leave a comment:
what version for HP 640G1 please i wanna solve {warning machine is not in committed state}
what can i doLeave a comment:
Hello!
I am trying to unlock the MPM on my Elitebook 840 G2 because I failed the initial branding after I changed the motherboard.
I tried the above method, and after I launch UefiMpmUnlock.efi in EFI shell, I receive the following message: HP MPM protocol is not present.
What do you guys think I am missing here?
I also tried to find a way to unlock the MPM via BIOS programming with no success. Could someone tell me how to find the byte controling MPM state in the BIOS?
Thanks!Last edited by GGN; 12-03-2020, 08:34 AM.Leave a comment:
SOO.. in case anyone else is wondering, I actually managed to unlock the MPM by running UEFIMPMUNLOCK.EFI in nbdmifit 2.13 from the EFI shell. Even though the program says it's not supported on my system (2.14 would be the right version, but has no UEFI) . After MPM unlock I can use the normal tools nbdmifit or wndmifit to write the detailsLeave a comment:
Hi! Can someone help me with my HP bios please? Dump here https://www.badcaps.net/forum/showth...23#post1004223Leave a comment:
by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
Channel: BIOS Requests ONLY!
by tsavpynDear all,
I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
Now I have a problem that I am unable to dump my BIOS into bin file.
My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
I searched for FPT but there is no Linux version and none of them work.
I hereby request a copy of Intel Flash Programming Tool for Linux x64.
I would really appreciate it if anyone...-
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank youToday, 06:42 AM -
by tony359HI all,
I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because... - Loading...
