bios for HP EliteBook x360 1030 G2
  • recan21
    • Oct 2018
    • 23
    • Algeria
    Re: HP EliteBook x360 1030 G2...help
    thank you!
    i have desolder winbond 25Q64 before seen your reply.
    and replace it now pc only led blink white/red .not power on!
    • recan21
      • Oct 2018
      • 23
      • Algeria
      i think i have destroyed the EEP by using hot air soldering .
      • recan21
        • Oct 2018
        • 23
        • Algeria
        ok now pc power on ! clean and replace ic bios carefully!
        • recan21
          • Oct 2018
          • 23
          • Algeria
          it's ok :
          https://www.badcaps.net/forum/showthread.php?t=73926
          • recan21
            • Oct 2018
            • 23
            • Algeria
            hp elitebook x360 1030 G2 BIOS!!
            i have already posted in this forum about this pc !
            i need bios with no password for:
            HP EliteBook X360 1030 G2
            motherboard : OLDMAN-6050A2848001-MBA01
            bios chip : MX25L128
            dump readed by EZP2013 programmer.(attached file).
            any one can help !! thanks
              • 21932
              Re: hp elitebook x360 1030 G2 BIOS!!
              Try this one .
              • recan21
                • Oct 2018
                • 23
                • Algeria
                #27
                Originally posted by SMDFlea
                Try this one .
                thank you !
                But black screen with tis file.
                  • 21932
                  Your bios was corrupt, i tried to fix it. Try this bios it should be ok this time, but you will have no DMI info, you have to use nbdmifit .
                  nbdmifit. https://www.badcaps.net/forum/showthread.php?t=69204
                  • recan21
                    • Oct 2018
                    • 23
                    • Algeria
                    #29
                    same thing : black screen and fun speed high than normaly.
                    my pc is clean from virus.
                    here another backup try to verify if corrupt or no!
                    thanks
                    • recan21
                      • Oct 2018
                      • 23
                      • Algeria
                      #30
                      is there any one here to help !!
                      pc now is black screen.
                        • 21932
                        thanks
                        The flash descriptor is missing,same as the other backup you made.The previous bios i posted should have worked ok, but i think you`re not writing the flash descriptor back. If you`re using a sop8 clip that might be the problem,always better to desolder the bios,or the bios chip is faulty .
                        • recan21
                          • Oct 2018
                          • 23
                          • Algeria
                          #32
                          i solder bios directly from mother-board to programmer using wires.
                          and erasing/writing operation was successfull.
                          must i desolder the chip and solder it on adapter ?? in oreder to get more success ?
                            • 21932
                            You must disconnect the laptop battery, and also the CMOS bios battery first before reading/writing or removing the bios.
                            • recan21
                              • Oct 2018
                              • 23
                              • Algeria
                              #34
                              other thing what about buffer offset and file offset settings ??
                              value is "0" . Do i change it ?
                              • recan21
                                • Oct 2018
                                • 23
                                • Algeria
                                #35
                                where is located "the CMOS bios battery" don't see it !!!
                                  • 21932
                                  I don`t know where the cmos battery is on the board,i looked at some motherboards on ebay and can`t see a soldered bios so it must have a connector somewhere.Some boards don`t have a cmos battery,they use the main battery. Unplug the main battery,press the power button for 30 seconds or more to discharge.Unplug every connector you can see, check bios volts, if 0 then flash the first bios i posted. Good luck with it , i`ll check your progress tomorrow.
                                  • recan21
                                    • Oct 2018
                                    • 23
                                    • Algeria
                                    #37
                                    ok thank you !
                                    i will try and post result.
                                    • recan21
                                      • Oct 2018
                                      • 23
                                      • Algeria
                                      #38
                                      sent ok check msg!!
                                      thanks.
                                      • recan21
                                        • Oct 2018
                                        • 23
                                        • Algeria
                                        #39
                                        bios unlocked ok thanks to all !
                                        • Duvelhedz
                                          • Oct 2015
                                          • 20
                                          #40
                                          Would anyone have a working dump for this machine. I have one here and the previous person messed with the bios and corrupted it.
                                            HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:27 AM
                                            HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 06:40 AM
                                            09-06-2024, 05:33 AM
                                            HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-06-2024, 11:32 AM
