Asus X552V bios dump needed
  • salawayon
    • Nov 2012
    • 578
    • philippines
    infos:
    asus X550CL rev: 2 board model..
    no display problem on this unit...
    backup attached...
    thanks....
  • cacla
    • Apr 2015
    • 444
    Re: Asus X552V bios dump needed
    Try this one
    • salawayon
      • Nov 2012
      • 578
      • philippines
      i tried your file but still the same... i already tried to disable the on board ram... any other dump for this unit? btw, upon power up the system fan spin continuously....
      • cacla
        • Apr 2015
        • 444
        Pls sent me sn i will find in asus system the right bios for tou
        • currier27
          • May 2016
          • romania
          ok tested
          • ArkzG
            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
            by ArkzG
            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
            What I currently have available:
            - Model: FA506NF (2021)
            - BIOS chip: GD25LQ16 (16Mbit/2MB)
            - Tools: CH341A programmer ready to use
            Does anyone have either a clean 2MB .bin dump of this model,...
            09-26-2025, 09:34 PM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
