So i changed the version of winrar which triggers the antivirus so now to old winrar 3.11.
I also alleviating python and removing unnecessary files.
also reduces splash screen time.
Files scanned with VIRUSTOTAL.com, it's OK now.
The archive goes to 20MB at 6MB with the new version.
Something else :
We would love to have feedback if you use our patch, bios, cleared password, or any other service provided on this forum.
Many members help you here.Don't forget !!
We need your feedback to move forward or look for other solutions for you.
Thank you very much for your work done. It's nice to deal with professionals
With the patched dump, the laptop shows a black screen and plays a melody sound that translates to code 0285 (TPM issue or so). I also tried to clean the ME Region as well and same result with code 0285.
BIOS dump version is 2021 - could it be the issue?
Attached is the original dump. If I put back the original dump, it turns on fine but with SVP pass.
I'm not sure if my request fits this topic or should i create a new one.
Anyway, I have a Lenovo T520 with Computrace enabled.
I tested a few things and came to the conclusion that Computrace enable/disable bit is located in 24rf08 IC. I read my ic and downloaded another dump with computrace disabled from the internet copied my serial number to that dump and flashed my ic.
Computrace was gone, but now I have a 0189 RFID error each time I boot the laptop up, so flashed back to my original dump and everything went back to normal.
I wonder if anyone knows in which address of the dump computrace enable/disable bit is stored ?.
In the attachment I posted a dump from my laptop with computrace enabled.
@TTR
You can use the 24rf08 eeprom dump you found and change CompuTrace setting to the different options, on each change then read 24rf08 eeprom again and you will know what's the offset where the setting is stored.
@TTR
Thnaks for the hint, based on dump modified by dani it's offset from 0x330 to 0x360.
