Thanks a lot, I tried adding a path before I posted message here, but more things were causing me problems. I managed to get started lenovo_autopatcher in cmd and successfully made a patch.
I also tried "LENOVO DXE Auto-Patcher" but to no avail. I put python 2.7.18, set the path, the program starts, I choose the bios that I would like to patch, it says loading, but no file is produced... the program could not even be installed on win7 64, while on win10 64 it could ..
There is a security problem on a file. A file remains read-only. I have to look at why this occurs on my patch.
You need Python 3. The cleanup step won't work with Python 2. If your machine is an older gen it doesn't matter, but newer generations need nvram to be cleaned.
Yes of course I used your patch with python 3.5.1, and it works perfectly.
I can confirm that I have successfully unlocked the X250.
Thank you so much for your work and commitment Knucklegrumble and Maxpower3.
I have one more question, how is the patching done when the laptop has two bios chips, as is the case with the T440p / T540p models. Which dump of those two need to be patched?
