In that way I try. Open command line administratior cd.. cd..
Then I copy link from folder press enter and i'm inside directory,insert autopatch.cmd press enter then nothing happens.what other I can do after I all command I insert? Then I need to insert bios bin from CMD or what?
hi,
why don't you integrate the Bios selection that I added? it's much easier to choose your file.
Thanks again for your patch
Because it only works on windows. I want the auto-patcher to work consistently across windows and Linux. Also leaving it more "lean" allows for easier integration with others tools (like you did).
You guys are welcome to modify the base script as you see fit to make it more convenient for you to use.
because it only works on windows. I want the auto-patcher to work consistently across windows and linux. Also leaving it more "lean" allows for easier integration with others tools (like you did).
Ok I understand your opinion.
So for beginners, I made this new version which is easier to use.
Only for Windows.
Just install LENOVO DXE Auto-Patcher.exe
And Click on desktop shortcut.
Need Python 2.7.X
Ps:"there is no interface for the moment, I have to finish the multi bios Patcher for that"
For Windows 7 and 10 , 32b or 64b
-------- Auto patcher with file selection V2 Version Mxp -------
Special thanks to Knucklegrumble
-Version Mxp:
- Possibility to select your file directly
- Auto-install with shortcut on desktop
- Possibility of making several files in succession
- With additionnal splashscreen
Tested with version python 2.7
Tested ok on W10 and Win 7(VM)
