Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    For people want to learn, you can read here
    https://www.badcaps.net/forum/showth...&highlight=DXE
    Read carefully, u'll find patch for your board.
      Originally posted by crowntoy99 View Post
      lenovo t480s bios password
      Here you go.
      Try this one and let me know if it does the trick.
        Originally posted by touftaf7301 View Post
        Hello, i patched the X380 bios with bootoptions and lenovotranslateservice, all steps went good, cleared the password and flashed back the original bios and now, the NVME SSD is not detected anymore in the bios
        did someone ever had this situation ?
        Here's the dump
        thanks
        Did you reset the bios settings to the factory defaults after reflashing the original image?
          can someone help with this e480?
          thanks
            Re: T440p Please deactivate or disable computarce in given bios
            Originally posted by kamalkharbanda View Post
            Hello Everyone
            Please help me to disable or deactivate computrace permanantly in given bios of T440p. I shall be thankful to everyone.
            Did i post wrong ?????
              Originally posted by Knucklegrumble View Post
              Here you go.
              i dint check pach file iam sorry bro
              thanks you sou mach for replay
              i re flash mec now is ok
                Hello
                I tried to patch this bios but no luck
                i replaced the LenovoService.efi dose not work
                could you help me with this?
                in attachment there the original and patched one
                thank you
                best regards
                By the way this is X1 Carbon
                  Originally posted by daasco View Post
                  Hello
                  thank you
                  best regards
                  TRY THIS FILE AND VALID WITH ANY KEY GOOOD LUCK
                  Instructions for use
                  Remove all battery and CMOS battery
                  Step 1: to enter setup: password
                  Step 2: wait 20sec or more.
                  Step 3: Enter ANY hardware Id.
                  Step 4: Press 2x space bar when asked.
                  Step 5: Turn off the computer.
                  Step 6: Restore your original bios.
                    Originally posted by ghamidi View Post
                    try this file and valid with any key goood luck
                    instructions for use
                    remove all battery and cmos battery
                    step 1: To enter setup: Password
                    step 2: Wait 20sec or more.
                    Step 3: Enter any hardware id.
                    thank you i'll flash it now
                    but what different between your method and mine whats wrong i did , could you help with this?
                      unlock this bin please T550
                        Thank its worked
                        but i'm still searching for how to patch it by myself
                        thank you again
                          Let me know if this works.
                            Hello Everyone
                            Try this one and let me know if it works.
                            Thanks.
                              Originally posted by msnessay View Post
                              PLEASE X1 YOGA 3rd GENERATION MODEL 2019 WITH PASSWORD
                              CAN YOU PATCH THIS BIOS?
                              Give this one a try and let me know if it works.
                                Thanks Knucklegrumble. It's working
                                  Thanks.
                                  Thanks for your efforts dear . But its not working at all. computrace function showing still activated in bios
                                  Please send another patched bios.
                                  Thanks again
                                    Thanks again
                                    The patch does not remove computrace, it removes the supervisor password. Once you remove the supervisor password you are able to disable computrace yourself
                                    Did you have a supervisor password?
                                    Did the patched bios boot correctly?
                                      No it does not have any password. When i power on the laptop it asks for 2 options.
                                      option 1 is Token Password
                                      option 2 is Server Password
                                      I typed 12345678 in option 1
                                      and it shows recovery successful then i press F1 to enter bios setup. Afer entering the bios password(without any password). It shows computrace is enabled and activated. Which i am not able to select or change to deactivate permanantly.
                                      when i flashed your patched bios it stuck on blank screen after entering the password (option 1) 12345678. and does not enter in bios as well.
                                        I believe you might not have a supervisor password setup. The patch only works if there is a supervisor password. When you enter the bios and go to security does it let you change the passwords or are they grayed out?
                                          Its grayed out (computrace function only)
