When I compare lenovotranslateservice and bootoption they come out the same in hex editor extract. Why does the patch I created not work compared to yours?
NEVERMIND I found it.. I was able to compare several files on here and found the changes.
FINALLY!!!! After comparing the files and using both a hex editor and UEFITool I was able to find my problem. I then used the original file and made a patch as well. When I run a comparison it comes back exactly as the patch xdrive55 created. Just had to replace one last region and BAM.. Will have to try it out. Thanks for your help xdrive55 and for all who posted in this tread that contributed.
Hello, I've tried patching a Lenovo X1 Carbon Gen 6 to no avail. I'm always getting an 8 beep error code and a blank screen. I want to know if its just about replacing the modules or additional steps have to be taken. I had an earlier X1 Gen 6 patched successfully in this forum (thank you dani981).But when I use that bios file, it gets to where I press F1 to enter setup and then it writes "entering setup..." and then nothing happens. I extracted the modules from the earlier patched bios and used them to patch this current X1, but all I get is 8 beeps. I want to know if UEFI Tools alone is enough. I will be grateful if this file will be patched for me. Thanks in advance.
