Thank you for the reply and the help. With this DUMP, no image, no Melodic sound.
Machine type 20LN 20LM.
Write your original (lock bios dump) , and find on board eeprom (24rf08 ps08 or 08 8pin) in this eeprom is bios password, you must reflash this chip to remove svp pasword
Looking for help would prefer to learn more than someone else performing the patch. I'm working on a L470, when I replace pe32 OR the entire file in both LenovoTranslateService and BootOption I get the same result. Melodic sound that translates into code 0285 (TPM initialization failure). I'm using UEFI tool and using the replace option. Just a little nudge in the right direction would be helpful. Thanks in advance.
Hello, Yes it worked and thank you. I was able to compare the files and found my LenovTranslateService was the same. The BootOption was the same as well. What am I doing wrong?
When I compare lenovotranslateservice and bootoption they come out the same in hex editor extract. Why does the patch I created not work compared to yours?
NEVERMIND I found it.. I was able to compare several files on here and found the changes.
FINALLY!!!! After comparing the files and using both a hex editor and UEFITool I was able to find my problem. I then used the original file and made a patch as well. When I run a comparison it comes back exactly as the patch xdrive55 created. Just had to replace one last region and BAM.. Will have to try it out. Thanks for your help xdrive55 and for all who posted in this tread that contributed.
