Probook 450 g3 capslock blinking - BIOS
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    HI,
    At first power on , black screen and I hear 2 beep and 2 beep with different sound frequency .
    I reprogrammed bios with two differen dump and now no beep but capslock and numlock blink 5 time , after that no blink and fan turns at max speed.
    I read it's possible a general system board failure ?
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Probook 450 g3 capslock blinking
    Do you mean 2 short beeps and 2 long beeps?
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      No, it's strange but the duration of the beep it's the same.
      I would not open the case until I'm sure the problem is not the bios.
      But now 5 blinks seem to be a generic failure
      (I downloaded the dump from dr bios and vinafix )
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        at first, was there anything that damaged the original bios?
        were the 4 beeps repeating or performing once?
        a generic failure means the failure can be on any components. I guess it is due to incompatibility of the new bios dumps to your laptop. but I am not sure. it is also possible that they are compatible.
        is there any display with the new bios dumps?
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          The 2 + 2 beeps are repeated indefinitely, but I thought if the original bios was good, the dump should also give the same beep frequency.
          I have doubts about the dump because if I remove the ram I do not hear any warning beeps.
          No display
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            MB Code????
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              Without disassembly it, I read only x63 UMA i5 6 generation
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Try this bios. This is 100% tested ok. If still no display not a bios issue. Do check the mobo code before flashing.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  I disassembled the notebook, the motherboard has the correct number.
                  Replaced the bios but always 5 blink
                  I think it's a pch problem
                  I used a ram ddr3l 12800s 8 g
                  there are other tests like reprogramming the ec before doing a cpu rework?
                  Cpu is cold I try to check voltages
                  • jasko_jacker
                    • Oct 2014
                    • 1137
                    • italy
                    I reprogrammed bios chip with original bios and the cpu became hot,
                    I attached this bios , I appreciate if someone can check its integrity
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      so the original bios seems better.
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        before declaring the Notebook unreparable without replacing the motherboard, I sent the Bios to Doctor Bios and with my surprise the Notebook work fine.
                        I had tried several Bios with no luck
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Can you post that working bios here??
                          • jasko_jacker
                            • Oct 2014
                            • 1137
                            • italy
                            This is the bios but at startup appears:
                            system is booting in manufactoring program mode 33
                            I'm trying to fix it, reinsert serial, etc
                            Someone can help me how restore to normal mode ?
                            thanks
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              Every startup the number decrease of one unit, I think the solution is to insert motherboard data and when after a lot of startup the zero number is reached the system return in user mode
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Use hp BCU utility to fix manufacturing mode issue.
                                • rioreno
                                  • Feb 2009
                                  • 540
                                  • Indonesia
                                  thanks
                                  would you try this...
                                  hope it will help you..
                                  thanks and goodluck
                                  • YOUN
                                    • Feb 2015
                                    • 79
                                    • Burkina faso
                                    Plz help me to fix my bios hp probook 450 g3
                                    • Desdee
                                      • Mar 2022
                                      • Zimbabwe
                                      How do o fix probook 450 G3 high speed fan, blinking lights, beeping sounds and black screen. Please help
                                      • peste
                                        • 12786
                                        • ROMANIA
                                        posts the original laptop bios
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • the_raz
                                          Need (unlocked) bios for HP Probook 450 G3 Notebook
                                          by the_raz
                                          I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                          Laptop number 1:
                                          Model: HP ProBook 450 G3
                                          Motherboard part number:...
                                          12-17-2024, 03:37 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
