Hi,have anyone this dump?thanks in advance
ASUS X552MD - motherboard X550MD rev 2.0 problem
Re: x550md - kbc dump needed
i found this one if someone else need it..Attached Files -
Hi everybody,i have problem with this board. Laptop was after liqud spill,returned from waranty service. I carefylly cleaned everything where i saw water marks. First problem was with 3.3V regulator. I replaced it,3.3V running. Second with KBC,replaced and reflashed it,ok,works. Third problem was with bios,reflashed it and now laptop starts but... This board have 8 RAM (4GB) chips soldered on the board and one slot for additional DDR3..Without additional RAM,dont start. If i put some 4G RAM in,in bios i see 8GB,laptop start but for the first picture i wait arround 10s, this is first thing what surprise me..it takes too long.When i connect power for first time,it starts normaly with this 10s delay,boot normal and work.After restart,start again with this 10s delay but after ubuntu initialize graphic card,i have only black screen,caps key is working only display is black. sometimes it spontaneously reset bios settings-time,boot order.. In kernel log i have errors from ME engine but maybe is clean in this bios,i dont know.. I tried also another bios,from X552MJ-is the same motherboard with more features but practicaly the same,the 10s delay was here also.. Any ideas? or maybe functional bios dump to try? I have combination Intel Celeron + nvidia gfxComment
Re: ASUS X552MD - motherboard X550MD rev 2.0 problem
is there any part of the board that was not damaged?
probably there are still a few liquid-damaged ICs which you have to discover.
to do this discovery, do the following operations separately:
1- inspect which ICs are dirty on pins or on the under-IC area with more care.
2- let the black screen happen after loading ubuntu. then check which voltage rail is not present.Comment
thank you for your response.
yes some parts was also clean :-)
i will look arround chips better tomorow, at beginnig i found same dirt around one of the RAM chips,i cleaned it with IPA and brush under the chip, the same result, also tried decoupling internal ram chips from system with conf.resistors, bios showed me this time 4GB less but always the same so here is not the problem...
I meassured "big" voltages on coils and everything is present after black screenComment
So,today i inspected the board one more time under microscope, found nothing more..only suspectible thing was the RAM chip so i reballed it and other reflowed-only for sure when the board was preheated, but found nothig under.. Other chips looking ok,i see nothing from outside and the area arround CPU and GPU was clean from beginning..
I tried another thing- to test if the usb bootable disk was ok and is not corrupted and subsequently also the instalation on HDD, i tried to boot WIN7 instalation usb..it ended with bluescreen and message "BIOS in this system is not fully ACPI compilant. Please contact your vendor for an updated BIOS".. Question is now,is this hardware problem or BIOS? Worth it to try another bios or repair this one? I tried many bioses,when it was running,always with this 10s delay on start,maybe is it not error but feature :-)Comment
It is absurd that Windows 7 acts like the BIOS is from the Windows 95 era!ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mà mismo
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
I made a mistake with BIOS, i found exact type on the label, it is X552MJ-SX053H, not MD (motherboard number is X550MD - dont understand this funny numering) so i downloaded right BIOS dump, flashed externaly and then i flashed new version from manufacturer with bios flashing utility from running bios. But is always the same :-) only thing that it looks like it no more reset the BIOS settings - this must i confirm later, after more reboots. I can try to make installation USB for UEFI instalation, this USB was for MBR instalation i think.Comment
I installed win10,look ok for now,one thing i found more, if speedfan utility check all connected sensors,i have error from sensors on the SMBus,maybe is problem here..i will check all traces and components on this lines later,after installing all updates and drivers..
edit:one line is conected to the processor,right in the edge where the edge bonding glue is applied ,maybe is there some hidden oxidation..Last edited by fester; 10-22-2017, 10:00 AM.Comment
10s delay in first boot screen is intel me region problem. Just clean me your existing bios dump and things will be fine. If you dont know how to do this, then post your old bios here. I'll help you with clean me bios.Comment
Hi friend,here is my dumpAttached FilesComment
Your file is giving eroor if i try to replace me-region through intel flash tools, so i have replaced me through hex editor.
Try and post about resultsAttached FilesComment
this time it worked,i replaced BIOS region in BIOS dump and computer is running without this 10s delay..i must make more tests because of possible problems with reseting bios but it look promising this time..thanks everyone for helpComment
test this biosAttached FilesComment
by dhenionI'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
The original board was:
ASUS X510UNR REV 3.0 A
The replacement board is:
ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...1 Photo -
by iT0mT0mHi,
I have problem with detection RAM on this motherboard. When I install CPU(Ryzen 5 2600, 5 4500 or 5 5600G) DRAM Led is lighting all the time. I tried reflash various verion of bios using Q-Flash method and that not resolve my problem. I tried reflash bios by SVOD 4 but that not resolve problem too. All voltages is correct and I don't see any low resistance on coils and other elements on motherboard. I tried replace memory to other and nothing. I don't know where is a problem(maybe connections between cpu and rams socket?). Actually I have boardview for this motherboard and I have... -
by RofixHello everyone, I wanted to ask you for some advice, I have this Asus card that is giving me problems, with the thermal camera I detected some components that are getting very hot, I removed a component that was short-circuiting but I still have the super I/O that is getting very hot, can something be done to fix it? Thanks to everyone for any advice...
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by lazaro.089Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
CPU: Core i9-12900H
Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and... - Loading...
