Dell Latitude E5550 bios needed
  • quezon
    • Dec 2015
    • 70
    • Philippines
    #41
    Originally posted by imranromi
    Re: Dell Latitude E5550 bios needed
    Here is working bios.
    Thank you.
    • javed964
      • Mar 2020
      • 23
      • Saudi Arabia
      #42
      Try this bios.
      I tried This its work fine but after 30 minutes system went off automatically, and system not powering up, Then again flash with this bios and same thing happened after 30 minutes,​
        • 20682
        Service tag ? https://www.badcaps.net/forum/troubl...before-posting
        Clean the ME firmware https://www.badcaps.net/forum/troubl...=3#post1622422
        • Kamlesh Soni
          • Aug 2024
          • 12
          • INDIA
          #44
          Hello guys I need a clean me file of my bios
          Dell E5550
          serial number : 37R1PF2
          please clean me region
          it has no power
          • hoaca388
            Badcaps
            • Jan 2022
            • 11640
            #45
            Dell E5550
            it has no power
            Latitude E5550/5550
            Service Tag: 37R1PF2
            • Kamlesh Soni
              • Aug 2024
              • 12
              • INDIA
              #46
              Originally posted by hoaca388
              Latitude E5550/5550
              Thanks 😁
              • adamgouadma
                • Jul 2017
                • 179
                • setif
                #47
                Dell E5550
                serial number : 128Z062
                motherboard ZAM80 LA-A911P
                • shiyab
                  • Sep 2023
                  • 1322
                  • india
                  #48
                  Dell E5550
                  hi try
                  • adamgouadma
                    • Jul 2017
                    • 179
                    • setif
                    #49
                    Originally posted by shiyab
                    hi try
                    It didn't work, still no screen
                    • robert0934
                      • Jul 2023
                      • 7
                      • Netherlands
                      #50
                      Hi, i need to unlock locked BIOS from Dell latitude E5550 SVCTag G70VG72-6FF1
                      can someone help me? BIOS is stuck with wrong boot order
                      Thank you, if you need more info let me know
                      • peste
                        peste commented
                        Editing a comment
                        post merged..
                      • 20682
                      Read the bios guides, password topic, you should be able to unlock it yourself https://www.badcaps.net/forum/troubl...23#post1622423
                      • robert0934
                        • Jul 2023
                        • 7
                        • Netherlands
                        #52
                        I tried all different combinations from the guide including CTRL+Enter etc and extra E7A8 but no solution, it is stil locked, i think i need to flash the chip
                          • 20682
                          Ok, post your bios backups and someone will help.
                          • robert0934
                            • Jul 2023
                            • 7
                            • Netherlands
                            #54
                            Ok, finally i got the file, it's in a zip. Hopefully someone can clear the bios password for me. Thanks alot
                              SMDFlea commented
                              Editing a comment
                              Thread merged with existing topic.
                          • robert0934
                            • Jul 2023
                            • 7
                            • Netherlands
                            #55
                            I could fix the problem myself by using the generator on this website: https://1024kb.co.nz/bios-password-generator/#keygen
                            Extremely important are the following instructions, usefull for other members:
                            1. Use a USB QWERTY keyboard.
                            2. When entering an Uppercase character use Caps Lock, NOT Shift.
                            3. Press & hold the left Ctrl key when entering the password in Dell laptops, then hit Enter TWICE
                            If your Dell service tag suffix is -0001, stop right here. That suffix indicates that the Allow Master Password switch is turned off in BIOS. You can try downgrading your BIOS but most likely will need to use an SPI Reader to dunp the BIOS.bin file
                            Dell use 3 minor inconveniences to defend their BIOS security. Without following their protocol, even correct BIOS Master Passwords will fail.
                            So no need to change my BIOS file, it is working now by following the exact instructions.
                            • testinglaptops
                              • Oct 2022
                              • 76
                              • United Arab Emirates
                              #56
                              Re: Dell LATITUDE E5550 LA-A911P (I need BIOS for MAIN and EC)
                              Latitude E5550
                              Service Tag: JRPNH72
                              WORKING, THANKYOU.
                              • asubbotkin
                                AnrewS
                                • Mar 2024
                                • 4
                                • Moldova
                                #57
                                Hello guys I need to reset bios password
                                Latitude 5550
                                Service Tag: 2FPT874
                                  • 20682
                                  Latitude 5550
                                  Read the bios guides, try to unlock it yourself -
                                  BIOS guides, methods, resources and tools
                                  https://www.badcaps.net/forum/troubl...rces-and-tools
                                  • mcc carlos
                                    still learning
                                    • May 2022
                                    • philippines
                                    #59
                                    this file is came from hang logo but may be could help if you can clean it first
                                      • 20682
                                      Post the laptop service tag
                                      • re1nhold
                                        Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
                                        by re1nhold
                                        Hello Guys
                                        I'm currently fixing two different Dell latitudes,
                                        I need a E5550 BIOS - SERVICE TAG is: FSFB262
                                        So far I flashed about 6 BIOS from this forum already,
                                        none worked,
                                        only fan spin ~3s, LCD black, keyboard LED on/off ok,
                                        I tried manual extraction with scripts for ages so to speak. VM is untried yet.
                                        This laptop is not burnt, it seems to just have a corrupted BIOS.
                                        I extra baught ram. This has to work friends.
                                        Do you generate it this way in Windows in CMD?:
                                        Code:
                                        E5550A24.exe /writeromfile C:\bios.fd
                                        07-18-2025, 09:18 AM
                                      • Eradicatus
                                        Dell Latitude E5550 - Strange Internal LCD (BIOS?) Issue
                                        by Eradicatus
                                        I have a problem with my Dell Latitude E5550 laptop, in particular with its display.
                                        This laptop has been sat under my desk (unused) for quite a while and I wanted to reinstall Windows and use it for some ad-hoc testing.
                                        However, I am struggling with the display, which is playing up.
                                        1) When the laptop is left switched off, after switching it back on the internal LCD does not work. No images are displayed at all - no DELL logo on POST, no messages, no Windows desktop. But I can hear that Windows starts up correctly, so no issues with the rest of the system - must be...
                                        04-20-2022, 02:40 AM
                                      • Aarush653
                                        Dell Latitude 5340 corrupt bios - clean bios needed
                                        by Aarush653
                                        Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
                                        Worked good before failed flash now won't power at all.
                                        May have been a bad connection.
                                        Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
                                        32mb chip - 25Q256JVEN
                                        Attach Dell Bios Update file v1.14 - original Dell update...
                                        10-14-2024, 04:28 PM
                                      • TripTop
                                        Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                        by TripTop
                                        Hi
                                        i have dell latitude E7270 with following symptoms:
                                        - takes long time to restart.
                                        - sometimes powers on and then off
                                        - sometimes while working it just dies,
                                        From googling online bios clean could possible resolve this?
                                        i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                        As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                        I reinstall...
                                        09-09-2024, 02:05 PM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
