DAV03AMB8E1 rev E bios dump request
  • lefos
    • Nov 2013
    • 321
    • Greece
    I am wondering if anyone can provide a working dump of this dell motherboard.
    Voltages exist but no power. So I am thinking maybe there is a BIOS corruption.
    Attached are the original dumps of EC & main BIOS.
    Thanks in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: DAV03AMB8E1 rev E bios dump request
    see if it helps
    • lefos
      • Nov 2013
      • 321
      • Greece
      Thanks for your file but it is bigger than mine so it is impossible to flash it.
      Is it from dell's site? If so maybe somebody can split the file (because it has 2 chips).
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try this, might work.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Try another dump downloaded from 4shared folder. Not tested though.
          Please confirm about result
          • lefos
            • Nov 2013
            • 321
            • Greece
            Thanks again for helping me, I can confirm that bios files from post #4 work flawlessly.
            • XIXO123
              • May 2018
              • 6
              • SPAIN
              I have tried the bios from post #4 and is inestable, the sound don't work and the second time I started de PC doesn't start and the fans started spinning too fast.
                • 21586
                you need a bios with a clean ME region.
                • Mhvv
                  • Oct 2020
                  • Việt nam
                  thanks # 4 works well
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • haitham sharabati
                    by haitham sharabati
                    Hello engineers šŸ˜€,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
                    šŸ”§ Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    šŸ’€ Problem:šŸ˜…
                    - Device shows ā€œAdministrator Passwordā€...
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • greelidd
                    K6604J Vivobook RTX 4070 BIOS Dump Request
                    by greelidd
                    Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                    Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                    09-01-2025, 06:14 PM
                  • olfelys
                    HP Pavilion 500-560nf (Memphis-S, SSID 2B2C) – BIOS dump request (8 MB .bin)
                    by olfelys
                    Request: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
                    My board enters jumper recovery mode but no BIOS files are available from HP anymore.
                    I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
                    Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
                    post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...
                    09-05-2025, 12:38 AM
