HP ProBook 650 G2 6050a2723701-mb-a02
    Re: HP ProBook 650 G2 6050a2723701-mb-a02
    this bios me error late display and no boot anyone clean please
      clear
        Originally posted by gecon27 View Post
        Update:
        I managed to successfully flash BIOS, first on a HP ProBook 650 G2 (chip Winbond 25Q128FVSQ) and then on a HP ProBook 650 G1 (chip Macronix MXIC MX25L12873F), using in both cases the firmwares provided by SMDFlea.
        I include hereafter some notes based on my own experience:
        1) Neoprogrammer seems to do the work better than CH341A Programmer and AsProgrammer. Using the latter two you have to be very cautious which version of the software you will use in order to correctly support the chip(s) you're using.
        2) In both cases I did the reprogram with the chips on board. It is important to make sure that the machine is completely switched off by pressing the power-off button for 10 seconds or so before starting the programming. For the chips to be recognized, in my case at least the charger had to be unplugged.
        3) I downloaded DMI Tool 2.018.zip from https://drive.google.com/file/d/16XT...bjoay8pAx/view and created a bootable USB stick as per the instructions. Then I booted from this USB and followed the instructions to restore the parameters from the backup I had taken with the HP BCU utility before starting the programming (note: all parameters had to be typed in manually) and finally commit. Attached some screenshots.
        please some one update link google link not found
          Use the forum search engine before posting
          https://www.badcaps.net/forum/showthread.php?t=69204
          Become a Badcaps supporter
          Thanks to all supporters.
            Re: bios hp probook 650 g2
            not working fan runing fast
            have biose password plz clear anyone
              Read post #179
                hello. can someone fix my bios?
                  Please read the rules before posting.
                    thanks
                      I Have Hp circus 6050a2723701 mb a02 powers on no display. Pls can you fix the bios for me. SN 5CG6316M0F BOARD NO. CIRCUS 6050A2723701 MB A02
                        try.
                        i just clear me.
                          tank you
                            i have admin password anybody can help plz
                            HP ProBook 640 G2 original bios dump and boardview needed, can anyone help
                            Can someone please take a look at this bios? The board does not power on at all but voltages are present (19V/5V/3.3V/1.8V).
                            I already tried to put together a fresh bios with the existing ME but it did not solve the problem so I guess I must have done it wrong.
                            HP 650 G2
                            6050A2723701-MB-A02
                            SN: 5CG6451VRL
                              HP 650 G2
                              6050A2723701-MB-A02
                              SN: 5CG6451VRL
                              HP ProBook 650 G2 Base Model Notebook PC
                                Thanks! Board is still not working, it probably has other problems. When I plug in the power adapter it idles at 0.015A and briefly jumps to 0.200A when pressing the power button but it goes down again immediately. Keeping the power button pressed heats up an IC which is likely the 3.3V LDO. Should I replace the IC or does it indicate a problem with the EC or PCH?
                                  SMDFlea commented
                                  Editing a comment
                                  If its no longer a bios related issue start a new thread in the laptop troubleshooting forum.
