Unlock System Lock PIN Code
  • karim011
    • Nov 2016
    • 122
    • Morocco
    Hi guys. pls someone help me for Unlock System Lock PIN Code for macbook pro
  • techman1025
    • Jun 2014
    • 497
    Re: Unlock System Lock PIN Code
    Upload your bios file i will remove it and then will up load it whit out password
    techman1025
    • karim011
      • Nov 2016
      • 122
      • Morocco
      THANKS. its work
      • mnogo
        • Sep 2017
        • uk
        techman1025
        I have a Macbook Pro 2017 also locked. Do you think you can remove the password?
        • techman1025
          • Jun 2014
          • 497
          Yes i could but you need to upload your original bios file then i will remove it and upload a cleaned file and tell you what you need to do after you flash my file back.
          Techman1025
          • Curtissimo
            HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
            by Curtissimo
            Hi everyone.
            I have a HP Elitebook 850 G8.
            Serial: 5CG2324XM0
            ProdID 6L8D5EC#ABA
            It has a Winbond W25Q256JVEN Chip.
            I need to remove BIOS Password.
            I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
            Attached my dump.
            I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
            I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
            What I did:...
            08-26-2025, 04:42 AM
          • bouch
            unlock macbook air A1932 2019
            by bouch
            hi
            i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
            i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
            i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
            have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
            I need help or information?
            Does anyone have the minat2 activator 1.4 software?
            Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
            Thank yo...
            03-12-2025, 10:14 AM
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • x16
            Fujitsu Lifebook U7312 unlock code not possible
            by x16
            the most new Fujitsu laptops can be unlocked by mastercode. You write 3 words in bios (at passwords prompt) and get a code with that you can unlock the bios. But with my Fujitsu Lifebook U7312 the 3 words don't work: 3hqgo3 / jqw534 / 0qww294e.
            This work on all my other Fujitsu laptop, but not on U7312. Any Ideas?
            08-28-2025, 09:41 AM
          • Marc97
            Macbook A2251 actiVation lock
            by Marc97
            Hello friends... Do you have new idea, for what device or tools,, good to use for macbook a2251 activation lock.. It is T2 or maybe newest,, may i ask if theres like ch431,, ezp,,, etc.. New device to buy to solve activayion lock for t2 chips...
            03-01-2024, 08:59 PM
