acer aspire 4738z bios need main and ec
  • kiraro
    • Jan 2016
    • 177
    • North NY
    Re: acer aspire 4738z bios need main and ec
    Check LM393 ,or replace it with a good one .
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      Kiraro i cannot find the LM393 in the board.could you show me where is located?i dont have schematic for this.
      • kiraro
        • Jan 2016
        • 177
        • North NY
        i think this is the schematic of the model or approximately :
        see page 44 thermal protection (LM393) who generate system shutdown (SYS_SHDN# )
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          Thanks for the schematic kiraro i will try to find and check ill update soon
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            I checked the schematic and measured the pu10 LM393 voltage on pin 7 is 0.25v so i changed with the same chip LM393 from the scrapboard when i measured pin 7 there is now 2.4v but in the schematic output pin 7 of LM393 should be 3.3v. when i test the laptop still the same issue it turns on normal fan spins but after a second shuts off but led light is still present. any advise what should be next to check and replace? please help me
            • kiraro
              • Jan 2016
              • 177
              • North NY
              #26
              Mesure Pin1 of lm393 and (pin2 and 3) of pq39, Try also change U13 thermal sensor .see if there is another lm393 defective also.
              • kiraro
                • Jan 2016
                • 177
                • North NY
                #27
                After checking above try to Check System PWR_OK on U24 sys_pwrok if it is missing that indicate you are missing some voltages on mobo,that may help to know if all the voltages are OK or not .
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  #28
                  I measured pin 1 of lm393 0.25v and measured pin 2 and 3 of pq39 0.34v i did not found any lm393 only 1 at pu10 ive noticed when i press power on and fan spinning i measured pin 7 of lm393 its 2.4v but when fan stops it drops to 0.40volts there is no voltage also on U24
                  • kiraro
                    • Jan 2016
                    • 177
                    • North NY
                    #29
                    No voltage on u24 mean there is a missing voltage on mobo verify all voltage on coil(CPU core ,VGA core ,....),find your missing voltages according with schematic,check pu9 vo also.
                    • sedinfo33
                      • 6
                      • algeria
                      #30
                      plz I need bios bin file
                      hp compaq presario cq58-120sk
                      • Romulo
                        • Nov 2016
                        • 484
                        • Philippines
                        #31
                        Ill measured all the coil voltage near cpu and gpu core there is no voltage on the coil.only coil PL13 and PL14 have voltage of 3.3 and 5volts.i cannot find pu9 on the board.any advise please
                        • Romulo
                          • Nov 2016
                          • 484
                          • Philippines
                          #32
                          When i test again the laptop turns on seconds shuts off but this time no led lights present
                          • kiraro
                            • Jan 2016
                            • 177
                            • North NY
                            #33
                            Page 37,check if there ils a short on +3V_S5,+5V_S5,+5V,+3V ,if there is a short on s5 this is may be why she drop down after few seconds.if you don't find short make measure when turn on that +3v_s5 and +5v_s5 goes out without problem if not check S5D signal ,I have a problem before that +5s5 become 1,8v no short but broken resistance on s5 gate signal.
                            • Romulo
                              • Nov 2016
                              • 484
                              • Philippines
                              #34
                              I checked +3V_S5 at PQ17 plugged in charger there is no 3v also the same at +5V_S5 at PQ18 there is no 5v but when pressing power button fan spin and stops ill measured again voltage present 3v and 4.7 on PQ18.on +3v on PQ58 pin 6 1.7v and pin2 0v but pressing power button pin 2 and 6 have 3.3v the same on +5v on PQ56 pin 2 0V and pin 6 5v but pressing power button both pins have 5volts the same in PQ57 pin 1 and 2 novoltage pin 3have 3v but pressing power button still the same any advise please
                              • Romulo
                                • Nov 2016
                                • 484
                                • Philippines
                                #35
                                Anyone please help
                                • Romulo
                                  • Nov 2016
                                  • 484
                                  • Philippines
                                  #36
                                  Any help and advise on this please
                                  • Romulo
                                    • Nov 2016
                                    • 484
                                    • Philippines
                                    #37
                                    Any advise and help on this please
                                    • Romulo
                                      • Nov 2016
                                      • 484
                                      • Philippines
                                      #38
                                      any help on this please i still cannot find the culprit on the board
                                      • Romulo
                                        • Nov 2016
                                        • 484
                                        • Philippines
                                        #39
                                        Anyhelp please laptop fan still turns on then a minute shuts off but led lights steady
                                        • mannypokwang
                                          • Oct 2018
                                          • 5
                                          • Philippines
                                          #40
                                          Bro. Yung lm393 pin5&6 short ba?
                                          • EbrahimSiami
                                            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                            by EbrahimSiami
                                            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                            **What I have tried so far:**
                                            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                            07-02-2025, 02:31 PM
                                            ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                            ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 02:30 PM
                                            ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                            This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
