Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
    Re: Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
    Originally posted by Vesko356 View Post
    Find a matching schematic or boardview at the Schematic sub-section and find out yourself instead of asking here.
    Hint: SPI chip has a board position name U2803 ---> see pin #8.
    U2803. OK got it.
    Thank-you.
      thanks
        Hi! ASUS X555LF. Motherboard X555LD rev3.3. I have a broken onboard RAM. Can You create modbios with disabled RAM?
          Thank you
            My laptop turns off after 15 seconds, shows the Asus logo and even enters the bios if i want, but then turns off. Perhaps it is more likely that it is a failure in the electronics but I wanted to try a new bios just in case the failure comes from there.
            The model is X554LA-XX572T, serial number FAN0CV76621343D.
            The white sticker on the motherboard says X555LAB, and printed in white letters on the board X555LD Rev 3.6.
            I attach the backup of my board
            Thank you!!!
              Hey,
              I'm searching for BIOS file to ASUS F555LB
              Board: X555LD REV. 3.3
              Thanks in advance
                Originally posted by FreeDee View Post
                Hey,
                Thanks in advance
                Post the laptop serial number and a picture of the long white barcode sticker on the motherboard
                RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                https://www.badcaps.net/forum/troubl...ore-posting
                  Here it is. I hope that's correct ones
                    Vesko356 commented
                    Editing a comment
                    You MUST:
                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                      Name your thread with make, full model numbers and request
                      Provide a BIOS/EC dump if possible
                      Attach files directly to your post instead of linking to external websites
                      Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                  Hey,
                  Thanks in advance
                  Where is original backup bios file ?
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Here it is
                      Here it is
                      X555LB
                        X555LB
                        Thanks so much
