Bios HP 840 g1 - 6050A2560201-MB-A03
    Re: 840 g1
    Originally posted by genova View Post
    hi,
    another one who just light on power led and nothing more...
    try
      Re: 840 g1
      No change same problem
        Re: Bios needed for HP Elitebook 840 G1 (6050A2559101-MB-A03)
        Originally posted by razor_amd View Post
        Thanks, but it's not the right one. There is one Winbond W25Q128 chip and one Winbond W25W16 chip so the bioses are 16MB + 2MB. I found some bioses on ******** forum and flashed them but the result is the same.
        When the power adapter is inserted into the motherboard, all the lights for power on are immediately lit up. There are 3.3V and 5V standby. There is also voltage on coils for the battery charge (2 battery terminals) and one coil has about 1V. No other coil on the board has voltage. No voltage for CPU and no voltage for GPU. When I long press the power button laptop won't turn off.
        Is it maybe the problem with KBC? I will upload high res photo of the board to mediafire shortly...
        Mediafire
        were you able to solve the problem?
          Mediafire
          did you resolved?
            Please bios for HP 840 G1
            Hi everyone
            Please bios for HP 840 G1 6050a2560201-mb-a03 with Core i5-4300u processor.
            I attach the original bios
            Thank you for your support
              Re: Bios HP 840 g1 - 6050A2560201-MB-A03
              Thankx
                i have problem with 840 g1 MB -6050a2560201
                When i connect charger only charging led flash orange then white 3 times and thats all, can not power on, blank screen. ps I don't have battery. I tried to dump old bioses and flash one from this post but the problem persiste.
                Thank you all
                  som help to clean lossenord. thanks
                    Originally posted by shone984 View Post
                    som help to clean lossenord. Thanks
                      hp elitebook 840 g1 6050a2559101-mb-a03
                      Need bios repair hp elitebook 840 g1
                      board code 6050a2559101-mb-a03
                      serial no cnu416c0rb
                      product g7l11us#aba
                        no display please build this bios .
                          Try and report back
                            HP elitebook 840 g1 6050A2560201-MB-A03
                            Hp logo on hang problem
                            help me
                            Serial:5CG4470HVL
                            Product:KOD46UC#ABA
                              help me
                              Serial:5CG4470HVL
                              Product:KOD46UC#ABA
                              Upload your original bios and someone will help you.
                              all donations are welcome,
                                old bios
                                  old bios
                                  Here's your New bios file, try it and let me know.
                                  The Serial Number in the file was different from the one that you wrote, but it's for 840 g1 too.
                                  Serial Number: 5CG52326QP.
                                    Thanks Bro.......
                                      HP Elitebook 840 G1
                                      help me to fix bios of
                                      HP Elitebook 840 G1 6050A2560201-MB-A03
                                      the old bios
                                        Re: HP Elitebook 840 G1
                                        the old bios
                                        Here's your New Bios file, try it and let me know.
                                        Serial Number: 5CG5091Q9Z.
                                          Can someone repair these files? Is a dump from 840 g1 MB -6050a2560201-mb-a03 from dead board. I want to flash it on another same board. I think is not compatible because of chip matching and S/N number. Thanks
