HP compaq CQ40-108TU bios Need
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hi everyone. im looking for bios bin for this MOBO
    JAL50- LA-4101P
    Thanks in advance.
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: HP compaq CQ40-108TU bios Need
    HERE IS
    2 BIOS 1mb +2mb
    i think your file is 1mb
    • rickybucalan
      • May 2013
      • 322
      • philippines
      Originally posted by ridamouh159
      HERE IS
      2 BIOS 1mb +2mb
      tnx men..
      but still same problem.
      what do you think the problem. its turn on a few second and turn off?
      • djharold
        • Aug 2015
        • 239
        • COLOMBIA
        thanks, working
        • kero_kerokk
          • Aug 2017
          • 14
          • egypt
          thank
          u
          • alanzulfikar
            • May 2017
            • 10
            • indonesia
            Thank you my friend.. Its work :-)
            • larrydc
              • Apr 2014
              • 13
              • venezuela
              thanks a lot
              • priyatech82
                • Apr 2018
                • 3
                • india
                HERE IS
                2 BIOS 1mb +2mb
                can working with cq40 330tu ???
                • priyatech82
                  • Apr 2018
                  • 3
                  • india
                  halo sir i am looking cq40 330tu bios, please send
                  • Pascal Komlassan
                    • Jan 2017
                    • 806
                    • TOGO
                    someone can help me ? my machine turns on but no display the processor also does not heat up. here is his backup
                    • Pascal Komlassan
                      • Jan 2017
                      • 806
                      • TOGO
                      any help ????
                      • lorins_core
                        BlackSmith
                        • Dec 2012
                        • 551
                        • Philippines
                        JAL50- LA-4101P
                        Thanks in advance.
                        Can you send me the Backup bin. try to clean....
                        • Andyservo
                          • Jun 2013
                          • 152
                          • Indonesia
                          Thanks ridamouh159...
                          • vickey_vip
                            • Mar 2016
                            • 134
                            • India
                            HERE IS
                            2 BIOS 1mb +2mb
                            Thanks i have used 1mb file and it work fine
                            • bryanpoints
                              • Aug 2017
                              • 56
                              • Philippines
                              the bios bin its ok for me tested thanks
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11285
                                • Viet Nam
                                It's only 1 MB ?
                                • Rex009
                                  • Jun 2024
                                  • 4
                                  • India
                                  I got a laptop, named Compaq Presario CQ40 Notebook Pc. The problem is when I turn on the laptop without any internal hdd it directly boots into bios, in bios every thing work properly. But when I add internal hdd and turns it on, it shows Compaq logo and some other option at left corner to enter bios mode and then within few seconds it shutsdown automatically. If I select biso mode from this section, bios opens and detect every components properly like hdd, Ram etc.
                                  But when I chose hdd to boot windows it restarts and shows Compaq logo and then totally shutdown.
                                  When I attach bootable pendrive at usb shutdown occurs. But when I add keyboard at usb there is no shutdown problem.
                                  At bios settings I chose default bios settings but it's fruitless.
                                  Thanks in advance.
                                  Waiting for reply
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • DynaxSC
                                    by DynaxSC
                                    06-14-2024, 03:49 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • AppleLover123
                                    Acer Aspire A315-56-37qb mobo fried after programmed bios
                                    by AppleLover123
                                    Hello guys,
                                    i've got this Laptop from ebay the bios was bricked. I bought it a few weeks ago and flashed it with
                                    a CH341A Programmer first (Bios.bin attached) all that went good my bios worked and it booted up afterwards.
                                    Now i used it and wanted more memory so i went from a 4 GB 1Rx16 to a 16GB 1Rx8 .
                                    But it wont boot up with the new ram stick that i checked before in another laptop then i thought it was a good idea to flash the bios again
                                    with the same .bin so i dissasembled the laptop and took out the mobo and flashed the bios again (same way i did it before)...
                                    11-09-2024, 05:42 AM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
