hp 14-n075tx DA0U81MB6C0 bios
  • alihomee
    • Dec 2012
    • 1575
    • malaysia
    need biod dump mobo num isA0U81MB6C0 REV:c it comes with intel cpu with ati graphics
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: hp 14-n075tx
    the same bid
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Re: hp 14-n075tx
      check this
      • alihomee
        • Dec 2012
        • 1575
        • malaysia
        Re: hp 14-n075tx
        i will post results soon
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • AppleLover123
          Acer Aspire A315-56-37qb mobo fried after programmed bios
          by AppleLover123
          Hello guys,
          i've got this Laptop from ebay the bios was bricked. I bought it a few weeks ago and flashed it with
          a CH341A Programmer first (Bios.bin attached) all that went good my bios worked and it booted up afterwards.
          Now i used it and wanted more memory so i went from a 4 GB 1Rx16 to a 16GB 1Rx8 .
          But it wont boot up with the new ram stick that i checked before in another laptop then i thought it was a good idea to flash the bios again
          with the same .bin so i dissasembled the laptop and took out the mobo and flashed the bios again (same way i did it before)...
          11-09-2024, 05:42 AM
