Decript and resize an update hp file bios
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    I do this procedure to obtain a BIOS file that you can use with a programmer, if someone thinks that I have done something wrong correct me please.
    1 - download from the HP website, Notebook System BIOS Update file
    2 - decrypt it with phoenix tool
    3 - you get a file with extension xxxx.bin.DEC
    4 - with my version of the tool phoenix I get a file larger than necessary
    5 - delete the beginning of the file with a hex editor until you get the correct size, each hp bios file begins with
    YYYYYYYYYYYYYYYY
    Z ¥ ð ..........!.
    6 - save it with bin extension
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • iZakre
    HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
    by iZakre
    Hello everybody!
    To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
    The thing is that I had installed TeamViewer and could log into the computer...
    02-19-2023, 02:27 PM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • maanee11
    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
    by maanee11
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
    11-08-2025, 04:08 AM
  • akwky
    by akwky
    Hi!
    04-14-2025, 01:56 PM
