Dell latitude e7240
  • smali
    • Sep 2014
    • 287
    • Pakistan
    #41
    Re: Dell latitude e7240
    Originally posted by SMDFlea
    BIOS guides, methods, resources and tools
    https://www.badcaps.net/forum/showthread.php?t=103526
    3. Password removal by laptop brand
    3.4. Dell
    Thanks for your reply. I tried several times but couldn't succeed. Simple enter, control+enter.
    Can you please generate and share
    • smali
      • Sep 2014
      • 287
      • Pakistan
      #42
      Service tag is 462BJC2-E7A8
      • hoaca388
        Badcaps
        • Jan 2022
        • 11878
        #43
        US layout keyboard is essential.
        • rbvndonh
          • Mar 2021
          • 162
          • B
          #44
          Kindly please help in repair BIOS 64bit. 32bit file is checked and proper one.
          I already tried clean ME but not worked. It just turn on withour 3 restarts.
          On other bios with clean ME it starts, so the only issue is BIOS.
          Dell Lattitude E7240
          Board Code: VAZ50 LA-9431P REV 1.0 (A00)
          sticker with service tag is damaged, it is not visible.
          on other bios i check there is i5-4300U.
          recovery of ST will be an aditional advantage.
          seems no CD-KEY for Windows.
          Thank you
          • rbvndonh
            • Mar 2021
            • 162
            • B
            #45
            Anyone could help?
            • minhdigital
              • Nov 2022
              • 758
              • Vietnam
              #46
              Originally posted by rbvndonh
              Anyone could help?
              Send to you
              • rbvndonh
                • Mar 2021
                • 162
                • B
                #47
                Sorry, but this is bioa with my service tag or elswhere available bios? Thanks
                how to find my service tag?
                  SMDFlea commented
                  Editing a comment
                  The service tag in the bios you posted is GJK6TZ1 .It should match with the service tag number on the base sticker
              • moshu
                • Oct 2024
                • 66
                • Ireand
                #48
                I have a Dell e7240 with a motherboard from ebay. When is booting I am getting "FW status recovery Error" but that's not an issue.
                From time to time, Laptop is freezing while booting and that's annoying .
                I've tried to downgrade/upgrading the Bios, but still same symptoms. While upgrading/downgrading Bios version, I could see some messages, which indicates laptop would not being able to properly upgrade "ME firmware end-up ..."
                I've tried to read the Bios from the two chips but not sure what to select from the manufacture list for 25q064A 25q03513 . I am using T48 Programmer and doesn't have the auto-detect option, and with CH341 with auto-detect option was showing XMC as a manufacture.
                MB version LA-9431P
                Service tag 7396M12
                Please advise what is the manufacture options for 25q064A 25q03513 IC, and a piece of advice if writing a new BIOS on those will fix the issues ( "FW status recovery Error"​ and freezing screen )
                Thanks in advance
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11878
                  #49
                  MB version LA-9431P
                  Service tag 7396M12
                  Please advise what is the manufacture options for 25q064A 25q03513 IC, and a piece of advice if writing a new BIOS on those will fix the issues ( "FW status recovery Error" and freezing screen )
                  Thanks in advance
                  Click image for larger version  Name:	IMG_20221117_100612.jpg Views:	0 Size:	806.9 KB ID:	3524191
                  This's bios chips.
                  • moshu
                    • Oct 2024
                    • 66
                    • Ireand
                    #50
                    This's bios chips.
                    Thanks hoaca388,
                    I was able to identify the chips on the motherboard but my question was what to choose when I am selecting the IC inside the programmer (TL48 ) for 25q064A and 25q03213.
                    CH341 with auto-detect option was showing XMC as a manufacture for 25q03213.
                    • moshu
                      • Oct 2024
                      • 66
                      • Ireand
                      #51
                      Eventual I've read the 25q064A and 25q03213 ICs using CH341 where identify the chips as being XMC (XM25QH16B and XM25QH80B)
                      TL48programmer is not able to recognize the chips and not able to read those either I am choosing Micron or XMC from list.
                      Attached the bin files below. Please remove the FW status recovery Error
                      DELL e 7240
                      MB version LA-9431P
                      Service tag 7396M12​
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11878
                        #52
                        DELL e 7240
                        MB version LA-9431P
                        Service tag 7396M12
                        Latitude E7240 Ultrabook
                        Service Tag: 7396M12​
                        • moshu
                          • Oct 2024
                          • 66
                          • Ireand
                          #53
                          Thanks Hoaca388, did worked
                          Dont have the Error while booting.
                          Hope will fix the freezing image issues which were there from time to time
                          • Stantechs
                            • May 2011
                            • 27
                            • Nigeria
                            #54
                            bios .
                            Thanks bro, working
                            • albologna
                              • May 2022
                              • 28
                              • italy
                              #55
                              Hello
                              Can someone help me rebuild this bios on Latitude E7240
                              It starts but no Image
                              Latitude E7240
                              Service tag BG09YY1
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11878
                                #56
                                Originally posted by albologna
                                Hello
                                Latitude E7240
                                Service tag BG09YY1
                                Service Tag: BG09YY1
                                • albologna
                                  • May 2022
                                  • 28
                                  • italy
                                  #57
                                  Nice work. Thank you
                                  • reformatt
                                    • Feb 2020
                                    • 1417
                                    After a Clean ME of this BIOS for E7240, not sure how to do this on a split BIOS myself. Doing some odd things with power button, but button checks out ok. Want to eliminate this first. Dumps attached are for U1 and U2. Service tag is HV65F12.
                                    • LBTT1121
                                      • Nov 2024
                                      • 593
                                      • Việt Nam
                                      #59
                                      try post # 56
                                        • 21145
                                        Can you use a hex editor ? .You can join files from the command line on windows https://www.badcaps.net/forum/troubl...87#post1457587 ,not sure how to do that on a Mac
                                        Someone posted file joining and splitting software, havn`t tried it myself
                                        https://www.badcaps.net/forum/troubl...43#post3695743
                                        FIT/MFIT will split the files back again after building the new ME firmware.
                                          DELL Latitude E7240 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude E7240 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7240 boardview and E7240 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 05:30 PM
