Aspire one D257 bios
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    hello every one
    i have Aspire one d257 with no display & need original bios file
    if any one have please share
    old bios is attached
  • nsb
    • Nov 2015
    • Rj
    Re: Aspire one D257 bios
    try this
    • Ajadi muhammed
      • Nov 2015
      • 6
      • nigeria
      Pls what are you going to use the original bios file for
      • Ajadi muhammed
        • Nov 2015
        • 6
        • nigeria
        hello PLS I am a novice what do you use the original bios file for
        • imranromi
          • Jan 2015
          • 1290
          • Pakistan
          Motherboard model send aspire one d257 .
          • innocentforeign
            innocentforeign
            • Jun 2013
            • 172
            • KSA
            we use bios file for what ?
            • innocentforeign
              innocentforeign
              • Jun 2013
              • 172
              • KSA
              thanks nsb its working after flash bios
              • EbrahimSiami
                Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                by EbrahimSiami
                I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                **What I have tried so far:**
                1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                07-02-2025, 02:31 PM
              • bondminer009
                Need Bios for Latitude 7650 (No Original / dump bios file)
                by bondminer009
                Good Evening,
                Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                Thank You
                Salam,
                Three
                11-12-2024, 07:48 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • joshAU
                BIOS file for N550JK (original dump attached)
                by joshAU
                Hi all.
                I'm looking for a BIOS file for an Asus N550JK.
                I have a Asus R552J, which I believe is identical to the Asus N550JK.
                I downloaded the latest BIOS (210) for the R552.
                It is named N550JKAS.210.
                The BIOS file is however only 6mb in size.
                I've read the chip with a CH341A programmer and verified the file.
                That file is actually 8mb in size.
                I'm wanting to remove the BIOS password from this unit.
                It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                08-09-2022, 08:06 PM
              • adelage
                Merge ECS Z77-H2 bios cap file with original dump
                by adelage
                I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                03-11-2025, 03:07 AM
