dell vostro 3500 bios dump needed
    Originally posted by dikmen View Post
    dell vostro 3500
    reg.type no:p90f005
    st:F76MFD3
    MB:GDI4 LA-K032P
    I TOOK IMAGES WITH OTHER BIOS BUT I COULD NOT SAVE THE SERVICE NUMBER
    .I TRIED SEVERAL BIOS BUT IT COULD NOT BOOT
    THERE IS NO IMAGE WITH THE ORIGINAL BIOS, IT CONTINUOUSLY RESETS
    Read chips agian , file's corrupted.
    Become a Badcaps supporter
    Thanks to all supporters.
      Unfortunately, these are the files I saved. I tried by copying other files to the chips.Please help, is there any other option?
        model: dell vostro 3500
        reg type no p90f005
        mb:gdi4 la-k032p rev:1.0
        servis tag:f76mfd3
        My device does not start with the original bios. When I sent it before, I was told that the bios was corrupted.
        My device turned on with the bios I sent, but the service tag. I can't change it, it opens with an alt+f warning every time I open it.
        Please service tag. help me fix it
          reg type no p90f005
          servis tag:f76mfd3
          The original bios of the notebook is corrupt, it started with the bios I sent, everything is working normally, but I could not install the original service tag and the fan is running high at every startup and it gives the alt+F warning.Please help me save the original service tag
            Hello!
            Please help me remove this bios password.
            Dell Vostro 3500
            Service Tag: 50V22D3
            Express Service Code: 10936076151
            Board model: GDI4A LA-K032P Rev:1.0 (A00)
            Thanks!
              Originally posted by ava123 View Post
              Hello!
              Dell Vostro 3500
              Thanks!
              Thread merged. Read the password guide and have a go at unlocking it yourself - https://www.badcaps.net/forum/troubl...23#post1622423
                Thanks for moving my post here and i apologize for my mistake!
                My code suffix is 0001.
                8FC8 Patcher software works for this suffix too?
                When patching the 8mb bin file, the patcher gives me this error "wa nakita ang unang pattern" (did not see the first pattern).
                Patching the 16mb bin file is not working.
                  SMDFlea commented
                  Editing a comment
                  No, patcher doesn`t work with 0001
                Originally posted by kalilinux25 View Post
                Fresh from WEBSITE , CLEAN ME REGION , DMI added, please give feedback
                I changed the service tag in hex editor in those bin files but i can't disable de manufacturing mode...something is not matching.
                If anyone can help me removing the bios password from my bin files i would be grateful.
                  Hello
                  my laptop stopped turning on.
                  I saved the damaged dump "old64 and old128" and flashed the working dump that I downloaded from the previous posts "Vostro 3500_FT6BSD3(1) and Vostro 3500_FT6BSD3(2)", after which the laptop started working correctly, but constantly gives the error "manufacturing mode active" and the coolers work at full power. If press alt + F before loading the OS, or FN + X the coolers work correctly. However, after restarting the same problem again.
                  Please help disable "manufacturing mode".
                  Vostro 3500 LA-K034P I5-1135G7
                  ST: 4L3RPH3
                    Hello you can try this new files i build from your original BIOS me be it helps you.
                      I flashed two BIOS chips, the device does not turn on, the LED indicator flashes 3 amber and 6 white (corrupted BIOS)😥
                      I downloaded the BIOS recovery file from the official Dell website (BIOS_IMG.rcv), the laptop tries to read the file from the flash drive (the LED reading indicator on the flash drive blinks), but the BIOS is not restored.
                        Hello! I found a board for my laptop that had a faulty 16 MB chip on it. I downloaded the BIOS from the Dell website and flashed it.
                        The laptop is working, but after entering the service tag, I'm stuck in Manufacturing Mode. Alt +F does not help. Can you help me?
                        Model: Dell Vostro 3500
                        Motherboard: GDI4A LA-K034P Rev: 1.0 (A00)
                        Service Tag: FNPQ7F3
                        I would be grateful for any member than can help. Thank you!
                          Try
                            Originally posted by qayyum786 View Post
                            Try
                            Super! Everything worked perfectly! Thank you very much!
                                Try
                                1000% Work.10000 Thanks
                                  Hello. Please rebuild the bios for dell vostro 3500 motherboard LA-K032P. Service tag BY0V1D3. The laptop turns on, the fan spins, the processor heats up but does not display. I attach the original bios.
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                  Try from post #133. Its a Clean Configured and Unlocked
                                    Please restore the bios, The screen changes colors.
                                    LA-K032P Service Tag: F78L983
                                      Hi There,
                                      Can you please unlock this bios ?
                                      Service Tag : 5019SD3
                                      Board Model number :GDI4A LA-K32p rev 1.0 a00
                                      Vostro 3500
