Dump for HP Pavilion dv6
  • Esse
    • Apr 2014
    • 317
    • TOGO
    Please i need dump for hp pavilion dv6
    This is what it is writen in the machine setup:
    hp pavilion dv6 notebook
    numero de produit: QC639EA#ABF
    Version du BIOS: F.21
    Fabricant du BIOS : Insyde
  • Esse
    • Apr 2014
    • 317
    • TOGO
    Re: Dump for HP Pavilion dv6
    On motherboard i cant see the last numbers:
    PWA: HP MH- 40GAB7000
    PCB: HP MH-41 AB7400
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      here
      • Esse
        • Apr 2014
        • 317
        • TOGO
        MERCI beaucoup Dycc
        • Esse
          • Apr 2014
          • 317
          • TOGO
          Dycc,i try your dump but the machine doent power on.Please can you give the BIOS
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            WHAT IS YOUR BIOS SIZE ????? 2Mb 4Mb ??????
            • Esse
              • Apr 2014
              • 317
              • TOGO
              Sincerement je n ai pas la taille.j ai fait une mauvaise manupilation en enlevant mon BIOS qui s est explosé.j ai eu un autre BIOS WINBON sur une autre plaquette HP DV 6.Donc je cherche à programmer ce WINBON avec le bios de ma carte mere
              Honestly, I do not have the size. I made a bad manipulation by removing my BIOS which exploded. I had another WINBON BIOS on another HP DV 6 board. So I am trying to program this WINBON with the bios of my motherboard
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                referring me to the motherboard code you gave the BIOS has a size of 2mb.
                I attach another image
                • Esse
                  • Apr 2014
                  • 317
                  • TOGO
                  Thank you Dycc. Please Dycc, can reprogramming the BIOS be the solution to a machine that does not detect a good hard disk even in SETUP?
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    normally from the diagram you must first check that the hard disk is powered (5v 3v) and on the sata data transmission port there is no short circuit or faulty component (non-polarized link capacitor) . If after the tests it turns out that everything I have just listed above has no problem, replacing the chipset remains the alternative to solving this problem.It is also possible (in the case where the player CD works, and you do not have an infrared soldering station) to redirect the sata port of the hard disk to that of the CD player.
                    • Esse
                      • Apr 2014
                      • 317
                      • TOGO
                      Please Dycc, which chipset are you talking about? And how do you recognize it on the board?
                      • cengiz1998
                        • Feb 2017
                        • 5
                        • turkey
                        Hello dv6-6c04st have bios in your hand
                        • cengiz1998
                          • Feb 2017
                          • 5
                          • turkey
                          I need dv6-6c04st bios
                          Do you have any?
                          • jatoi
                            • Jan 2015
                            • 83
                            • pakistan
                            thanks DYCC this bios is 0k
                            • kjosmofon
                              • Mar 2014
                              • 35
                              • mkd
                              thanks dycc bios is ok 100% tested and work great
                              • purushottam karn
                                • Aug 2017
                                • 15
                                • nepal
                                thank you File ok
                                • mahyar
                                  • Apr 2019
                                  • iran
                                  hi
                                  hp dv6-3147ca bios need
                                  product: xg880ua#abc
                                  DAOLX8MB6D1 REV D
                                  • peste
                                    • Dec 2016
                                    • 13343
                                    • ROMANIA
                                    try...
                                    • Chandaj
                                      • Aug 2020
                                      • 40
                                      • ZAMBIA
                                      Hello, am kindly asking for main bios files and EC for Hp pavilion Dv6-6000
                                      HPMH-40GAP6110-E0AO
                                      • peste
                                        • Dec 2016
                                        • 13343
                                        • ROMANIA
                                        HPMH-40GAP6110-E0AO
                                        post the full name and model of the laptop, main bios and EC ..
