acer aspire E1-410 BIOS dump needed
  • salawayon
    • Nov 2012
    • 578
    • philippines
    Infos:
    EA40--BM MB
    13233-1M
    48.40C10.01M
    thanks...
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    Re: acer aspire E1-410 BIOS dump needed
    try this
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      backup old bios and try this
      if you need ec, read old and post here
      Im Back... sort of...
      • salawayon
        • Nov 2012
        • 578
        • philippines
        The bios chip is not supported by my SP8-A programmer. It's winbond 25Q64FWSIG, it only support FV model... i tried to select FV then make backup but i'm not sure if it's a good backup. I haven't yet tried to reflash the bios chip. My backup is 8mb. And i only found 1 bios chip on this board.
        • salawayon
          • Nov 2012
          • 578
          • philippines
          I just tried using MXIC 25L6406E as replacement then used the above given files but both ended up on No Display problem...
          • salawayon
            • Nov 2012
            • 578
            • philippines
            any bios programmer could support this chip?
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              i have cheap EN25T80 programmer and it works fine once you have drivers working....
              and if even if it dont support that id, jucst click force id, select size and you are good to go
              • salawayon
                • Nov 2012
                • 578
                • philippines
                Thanks... but i'm afraid that it might end up a no display or a dead unit... BTW, the main problem with this unit is that it won't boot anymore on internal hdd and any usb drive. It can detect the main hdd as seen on bios setup. And any changes being made on bios setup and upon restarting it always goes back to default. And even the internal hdd had an OS installed like windows 7 or 8 it always show No Bootable Device Detected....
                • winkoko
                  • Feb 2013
                  • 28
                  • myanmar
                  thanks
                  • OopManthai
                    • Dec 2015
                    • 3
                    • dsfsdfsfd
                    thank you
                    • reandy
                      • Dec 2015
                      • indonesia
                      thanks....it works
                      • ossocomputer
                        • Jun 2014
                        • 8
                        • Indonesia
                        thnks
                        • arunbharti
                          • Oct 2015
                          • INDIA
                          where is ec bios acer aspire E1-410 plz help me
                          • downloadmega
                            • Mar 2016
                            • 10
                            • myanmar
                            thank a lot
                            • buddyrock85
                              • Oct 2016
                              • 5
                              • indonesia
                              thank for all
                              • crysisanu
                                • May 2016
                                • 7
                                • Sri Lanka
                                DA0R75MB6C1 any one have this bios bin plz
                                • Trisnaadi
                                  • May 2017
                                  • 11
                                  • Indonesia
                                  Originally posted by alihomee
                                  try this
                                  this bios lock by password, please give the password. thanks.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    its 1.8v chip. u need 1.8v adapter to program this chip else you will end up with no display only. If you dont have a 1.8v adapter then there is a way out to program this type of chip. See attached photo-it will be clear to you.
                                    • Bright IT Solution
                                      • Sep 2016
                                      • 12
                                      • Bangladesh
                                      ea40-bm mb schematic need
                                      • on/off
                                        • Oct 2016
                                        • 333
                                        • Indonesia
                                        Please, Use search button first, Of course after login.
                                        https://www.badcaps.net/forum/showth...ghlight=E1-410
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
