probook 4520S bios
    probook 4520S bios
    well entered the store with not turning on tag , inserted the charger and the dc jack led was blinking , i opened the machine to inspect visually and noticed someone has messed up with the bios , well , went for the bios for this laptop
    motherboard 48.4GK06.011
    tryed bios from a 48.4GK06.041 the most common im finding online , but this one have a discrete gpu , this board is a UMA version , only have I3 cpu and a hm57 chipset and kbc1098-nu SMSC
    tryed the dump found for de 4520s at 1bios.ru
    machine turn on , and does turn on backlight but no image on screen only the bakclight , another issue found is that the led of the dcjack only turn on for 2 sec once i press the on off , also not charging battery , guess could be a bad dump , not making it working properly
    so if anyone have a bios for this motherboard probook 4520s BOARD MODEL
    48.4GK06.011 UMA VERSION , I APRECIATE IN ADVANCE
    thk
    Re: probook 4520S
    btw have cheked the charger ic , BQ24740 and all seems ok . so really hoping this could be a bad bios .
    if anyone have this bios it iwll be welcome
      Re: probook 4520S
      48.4gk06.011
        Re: probook 4520S
        well the dump i installed its also a V.68AZZ
        let see it changes something on the overall code or else got more problem on this machine
          Re: probook 4520S
          well no changes :\
            Re: probook 4520S
            cheking schematic for this board , who should send the white led for dc jack would be the KBC controler , the bloody thing is anoying me , is that the LCD turn on the the bloody backlight , but there is no image on internal or external !!
              Probook 4520s
              need bios dump , original dump if possible
                Re: Probook 4520s
                try this
                  Dump hp probook 4520s
                  Do you have a BIOS dump for this board maybe?
                  DUMP HP PROBOOK 4520S
                    Re: Dump hp probook 4520s
                    Here it is.
                      thanks
                        Re: Probook 4520s
                        thxxxxxxxxxxxxx
                          Re: probook 4520S
                          ısık var görüntü yok kendi biosula görüntü var
                          There is no light. There is no image.
                            thanks
                              Re: probook 4520S bios
                              This one should be correct:
                              in this model of motherboard the signature is the same for UMA and GPU versions, but the bios are different
                              remember to change motherboard serial number in bios after flashing
                              find a soft to do this by yourself
                                thanks bro... this works okay
                                  thanks
                                    HP ProBook 4520s S_Intel MB H9265- 48.4GK06.041 _bios dump Needed
                                    HI kindly help i flashed the Bios for hp 4520s but am only getting a white screen,no data.
                                    HP ProBook 4520s S_Intel MB H9265-_ 48.4GK06.041 _4MB bios dump.bin
                                      Re: HP ProBook 4520s S_Intel MB H9265- 48.4GK06.041 _bios dump Needed
                                      post the backup of the bios
                                        Hi, attached is the backup.
