hp pavilion DM1 bios file
  • salawayon
    • Nov 2012
    • 577
    • philippines
    AMD Chipset...
    Motherboard info:
    PWA: HPMH-40GAB6000-D
    PCB: HPMH-41-AB6000-D00G
  • oscarok1
    • Feb 2015
    • bucaramanga
    Re: hp pavilion DM1 bios file
    Originally posted by salawayon
    AMD Chipset...
    Motherboard info:
    thanks
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      backup old bios and try this
      "PWA: HPMH-40GAB6000-D
      PCB: HPMH-41-AB6000-D00G AB6000
      639297-001
      IC: 25Q16CVS1G"
      Im Back... sort of...
      • tabares
        • May 2012
        • estado de mexico
        thanks
        • aottel
          • Apr 2015
          • 4
          • palestine
          thanks
          • Laptop1703
            • Dec 2016
            • 4
            • India
            this bios fix display not come
            • toufik sat
              • Feb 2016
              • 134
              • los angles
              thanks
              • mohham
                • Sep 2014
                • 23
                • indonesia
                thanks
                • djharold
                  • Aug 2015
                  • 245
                  • COLOMBIA
                  thanks
                  • babu78
                    • Jun 2017
                    • 8
                    • tbilissi
                    thanks
                    • technician37
                      • Aug 2018
                      • 30
                      • philippines
                      thanks
                      • Carlos ivan
                        • Aug 2019
                        • 4
                        • Perú
                        Good morning everyone ... you will have the data bios dm1-10
                        And its board code is Daofp7mb6d1
                        • banghelmi
                          • Oct 2014
                          • indonesia
                          thanks
                          • BIOS20
                            • Nov 2020
                            • 17
                            • togo
                            hello, please i need a backup bios for this motherboard, help me please
                            • BIOS20
                              • Nov 2020
                              • 17
                              • togo
                              hp 3105m
                              Motherboard info:
                              • BIOS20
                                • Nov 2020
                                • 17
                                • togo
                                here is my save who don't work
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12108
                                  You should upload your broken original bios.
                                  • BIOS20
                                    • Nov 2020
                                    • 17
                                    • togo
                                    My old bios
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12108
                                      My old bios
                                      Did you choose the right bios chip?
                                      • BIOS20
                                        • Nov 2020
                                        • 17
                                        • togo
                                        yes this is my backup, now if you have a functional file please give it to me because the one posted above does not work for me.
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • iZakre
                                          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                          by iZakre
                                          Hello everybody!
                                          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                          The thing is that I had installed TeamViewer and could log into the computer...
                                          02-19-2023, 02:27 PM
                                        • ianhaney
                                          HP Pavilion DV2130ea bios bin file request
                                          by ianhaney
                                          I am new to the forum and looking for a HP Pavilion DV2130ea bios bin file. I can't seem to find one online, I can only find a exe file
                                          02-16-2025, 08:14 AM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
