I need help with an HP EliteBook 840 G8 BIOS repair.
  • fadee23
    • Dec 2023
    • AlgĂ©rie
    During the removal process, I accidentally lost the original BIOS chip, and unfortunately I don't have a backup of the original dump.
    I found a clean 32 MB BIOS file from another HP laptop with the same motherboard model, but now I need to insert my laptop-specific information (DMI data) into this clean BIOS image before flashing it.
    The information I need to restore includes:
    • Serial Number (S/N)
    • Product Number / SKU
    • System Board CT Number
    • Feature Byte
    • Build ID
    • MAC Address... ETC
    I want to modify the clean BIOS file using HxD, but I don't know where exactly these DMI fields are located in the .bin file...
    Can someone guide me on how to manually locate and edit the DMI region (NVRAM region) inside the BIOS dump, or confirm the correct offsets for this model?
    Thank you.
  • lap-top123
    Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
    by lap-top123
    HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
    Hp Elitebook 850 G8
    ProdID 52W98EC#ABD
    SN# 5CG1458XQ7
    Mac-address #1: 84:14:4D:2C:4B:5B
    UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
    Mainboard : 6050A3216701-MB-A01(A1)
    08-20-2025, 07:28 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • maanee11
    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
    by maanee11
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
    11-08-2025, 04:08 AM
  • Forest79
    by Forest79
    07-23-2023, 07:39 AM
  • maanee11
    Help to get Lenovo BIOS bin file for Thinkpad T560
    by maanee11
    Hello Everyone,
    I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
    https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
    In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
    05-15-2022, 11:59 AM
