HP Envy x360 15-fh0097nr
This topic has been answered.
  • compcellinfo
    • Aug 2023
    • 24
    This laptop is an HP Envy x360 15-fh0097nr. The client's brother had set a BIOS password that they could not remember and we were unable to find a BIOS pw bypass. I attempted dumping the chip with a clamp programmer (see attached), and verified the image successfully. I then tried reimaging the chip with the BIOS found on HP's website (both with the clamp programmer and soldered directly onto a CH341A), but every time I attempt a verify it fails. The computer now does not POST.
    The chip itself is a Winbond 25R128JWSQ, which does not appear to have a direct match in NeoProgrammer, but it does autoselect another Winbond chip and appears to execute most functions on it just fine. Any suggestions?
  • Answer selected by compcellinfo at 09-29-2025, 12:52 PM.
    m1ch43lzm
    • Mar 2019
    • 1047
    • Peru
    Try, I don't know which BIOS version you downloaded from HP website, the version from your backup is F.06, also attached latest version F.13, as there's a note in HP website
    - Provides enhanced security. NOTE: Due to the security updates installed by this BIOS update, previous BIOS versions cannot be reinstalled after this BIOS update is run.
    Your backup looks correct by the way
    BIOS extracted from HP website, serial/win key inserted
    HP Envy x360 2-in-1 Laptop 15-fh0097nr (7N486UA)
    BID 08BE9
    S/N CND33409GS
    DMI + Win key B1000-B203F
    Hope you didn't damage the BIOS chip, or the CPU if you used a clip (on AMD the BIOS is connected straight to the CPU) by sending 3.3V to 1.8V power rail/CPU (SOC) data lines
    • volinakis
      • Jan 2021
      • 2875
      • N/A
      post serial no.
      25R128JWSQ is 1.8v, use 1.8V adapter and chose 25Q128JW
      • compcellinfo
        • Aug 2023
        • 24
        Originally posted by volinakis
        post serial no.
        Oops, forgot the S/N: PF3JRR1J
        I didn't even know there was such a thing as a 1.8v adapter, I assumed the CH341A could handle multiple voltages :/
        Ordered a kit, should get it tomorrow.
        Should I also replace the chip? Is it possible I cooked it with the higher voltage?
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          PF3JRR1J serial is for Ideapad 5
          if chipset is detected by programmer (ID: xxxx) no need to replace it. Read 3-4 times and compare results, when you have 2 identical it means you have a good backup. CH341A doesn't verify the backup against the content of the chipset.
          • compcellinfo
            • Aug 2023
            • 24
            Jesus, it's been hectic in here this morning, I gave the complete wrong SN. This one is CND33409GS.
            Unfortunately I'd already tampered with the chip by trying to write to it so further backup attempts won't be very productive. Hopefully someone can cobble us together a functional binary I can flash onto the chip once I get the adapter in.
            • volinakis
              • Jan 2021
              • 2875
              • N/A
              try this file when 1.8V adapter is coming.
              • m1ch43lzm
                • Mar 2019
                • 1047
                • Peru
                BID 08BE9
                S/N CND33409GS
                • compcellinfo
                  • Aug 2023
                  • 24
                  BID 08BE9
                  S/N CND33409GS
                  Oh lord; I did indeed use a clip on the initial attempts. Is it likely I hosed the board?
                  This is a big facepalm moment for me, I didn't know the CH341A had voltage limitations
                  • m1ch43lzm
                    • Mar 2019
                    • 1047
                    • Peru
                    It depends if the clip made good contact or not... Sometimes it takes several tries to align the clip properly, if by chance pin 8 (VCC) didn't make proper contact there may be hope, if possible desolder the BIOS chip from the board and try again with the 1.8v adapter
                    Depends on which version of the CH341A you have, there's one with black PCB with rounded end which is 3.3V, with those you have to use 1.8V adapter for 1.8V chips (all AMD Ryzen, some Intel platforms)
                    There's another CH341A version with a voltage selector switch
                    Best to get a better programmer that supports more chips, there's the T48, RT809H, T76, REVELPROG-IS, SVOD4 (this one also does EC programming)
                    • compcellinfo
                      • Aug 2023
                      • 24
                      Thanks for the advice, I'll look into those options. We definitely have the 3.3v version with the rounded-off end. I'm pretty sure I had that sucker on there good since I was able to dump the chip and supposedly to write to it. Hopefully I didn't fry the client's board, that would be... unfortunate.
                      • compcellinfo
                        • Aug 2023
                        • 24
                        m1ch43lzm tried flashing the F06 version; I get programming "success" but then it quickly fails a verify pass. Tried this both on and off the motherboard. Should I bother trying another chip?
                        *edit: Verification also fails on F13.
                        **edit edit: tried soldering the chip to the adapter thing, still get the same verification error. I'm gonna go ahead and order a couple of these chips.
                        • compcellinfo
                          • Aug 2023
                          • 24
                          @m1ch43lzm update: new chip flashed fine and computer now powers on. I do get a message declaring "manufacture programming mode is in unlock mode", and I'm not sure how to make that go away, but it does POST and attempt to start Windows. Obviously we're hitting a BitLocker wall but this is much better than it was!
                          Edit: apparently we just need to get it into Windows and run the HP BIOS Configuration Utility to get rid of that message at startup.
                          Thanks for your help, everyone!
                          • m1ch43lzm
                            • Mar 2019
                            • 1047
                            • Peru
                            For Bitlocker key, it's should be on customer's MS account
                            https://support.microsoft.com/en-us/...3-056f5ab347d6
                            Follow the instructions on the MS article linked above, if you can't get the key/customer doesn't remember MS account details, goodbye data
                            The "Manufacture programming mode", yes, use BCU to change it to *Lock, check if the serial/product name/SKU/feature byte is correct in BCU or BIOS setup (it should be as I copied from the old BIOS)
                            HP BCU https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                            • compcellinfo
                              • Aug 2023
                              • 24
                              Yup we already dug up the key, now he's gotta reset his PIN before we can run BCU. Thanks for your help!!
                                HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                09-06-2024, 12:18 PM
                                HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                09-06-2024, 11:17 AM
                                HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                                This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 06:51 AM
                                HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                09-06-2024, 06:50 AM
