Need Help Lenovo Thinkpad P16v Gen2
  • CraterM
    • Mar 2018
    • 178
    • Moldova
    Heloo
    i have problems with Lenovo P16v Gen. 2
    After write NPCK397 with SVOD, SVOD erasing 16mb EC. Without EC laptop is dead. But with another EC from similar laptop, turn on firts time, but after shutdown no power, no led light. Disconnect charger and reconected, laptop is turn on again but working to a first shutdown! With battery or CRC, no light, no power!
    Thanks!
    • 21099
    Originally posted by CraterM
    Heloo
    Thanks!
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • CraterM
      • Mar 2018
      • 178
      • Moldova
      Lenovo Thinkpad P16v Gen. 2
      Type 21KY
      SN: PF-55NA2X
      Board: NM-F841
      • volinakis
        • Jan 2021
        • 2743
        • N/A
        Heloo
        Thanks!
        how did you read NPCK397 with SVOD4? Does it need some special settings or can be read in same way as NPC997 for example?
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1226
          • France
          Type 21KY
          SN: PF-55NA2X
          Board: NM-F841
          Click image for larger version  Name:	image.png Views:	0 Size:	229.6 KB ID:	3664336
          there would be no offset in the file??
          1.13 or 1.14 same EC
          I would have seen it like that??
          • CraterM
            • Mar 2018
            • 178
            • Moldova
            Hello Max, i tried a few days ago with an official update and nothing. No power, no light. I tried with your ec... and nothing! No LIght
            Power is on only with another EC from secondary laptop. Today i received another identically laptop, Same probloem, after shutdown laptop not power on.
            • CraterM
              • Mar 2018
              • 178
              • Moldova
              SVOD reading correctly NK397 with 2,5v power. But first step is reading 16mb EC because SVOD erasing this EC. For you safery, first back-up on MAin 64mb and Ec 16mb
              • volinakis
                • Jan 2021
                • 2743
                • N/A
                Somebody from this forum said that is recommended to take out EC bios before reading NPCK397 - he was using a Succesor. I will be able to help you with Ec bios in 2-3 days if it's not too late. Thank you.
                • CraterM
                  • Mar 2018
                  • 178
                  • Moldova
                  After I erase accidentally this EC on the laptop, I made two P16v Gen.2. Svod working perfectly, but first rule is save your EC
                  • Ponto da Manutenção
                    • May 2024
                    • 97
                    • Brasil
                    Heloo
                    Thanks!
                    Does this version only use one bios?
                    • CraterM
                      • Mar 2018
                      • 178
                      • Moldova
                      Main 64mb and Ec 16mb
                        • May 2024
                        • 97
                        • Brasil
                        Are you sure your backup (MAIN) is 100% verified?
                        • CraterM
                          • Mar 2018
                          • 178
                          • Moldova
                          Of course!
                          • volinakis
                            • Jan 2021
                            • 2743
                            • N/A
                            Heloo
                            Thanks!
                            when you put bios from another laptop you have to clean ME main bios. In ME Firmware update for P16v gen 2 there are 2 files: Corporate and Consumer. this one you posted it has Corporate ME firmware, I did a clean Me and use it for main bios along with file posted here for EC bios. Post Main bios from not working laptop maybe it has Consumer ME firmware and that's why is not working with your bioses from another laptop.
                              • May 2024
                              • 97
                              • Brasil
                              Can you open this file in MEA?
                              • volinakis
                                • Jan 2021
                                • 2743
                                • N/A
                                no, ME 18 fw is not recognized by MEAnalyzer.
                                • CraterM
                                  • Mar 2018
                                  • 178
                                  • Moldova
                                  Thanks a lot but same issue. After shutdown laptop is dead.
                                  this is original dump with lost EC
                                  • volinakis
                                    • Jan 2021
                                    • 2743
                                    • N/A
                                    it's the same (Corporate fw). Why don't you try to do a bios update when it starts?
                                    • CraterM
                                      • Mar 2018
                                      • 178
                                      • Moldova
                                      I tried, but I get this error. Battery not detected!
                                      • volinakis
                                        • Jan 2021
                                        • 2743
                                        • N/A
                                        try with clean ME bios I sent you.
                                          Lenovo ThinkPad P16v Mobile workstation P Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad P16v Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P16v boardview and P16v schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 07:20 AM
