MSI GP62MVR 6RF (MS-16JB1) BIOS and EC Dump Request
  • freeelectrony
    • Jun 2025
    • 6
    • Türkiye
    Hello, I am looking for original BIOS and EC flash dump files for my MSI GP62MVR 6RF laptop. The motherboard model is MS-16JB1. My laptop is currently bricked and I have already tried updating the BIOS and EC from the official MSI support page without success. I need working dump files from a functional laptop of the same model. Any help would be greatly appreciated. Thank you!
    My laptop serial Number: K1609N0087662
  • Ponto da Manutenção
    • May 2024
    • 97
    • Brasil
    Done.
      • 20758
      Type the laptop serial number
      read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
      • freeelectrony
        • Jun 2025
        • 6
        • Türkiye
        Originally posted by Ponto da Manutenção
        Done.
        Thank you.
        However, this file is already on MSI's site and I tried it did not work.
        Did it work on your system?
        I need the dumped files from BIOS and EC flash chips in a working system.
        • freeelectrony
          • Jun 2025
          • 6
          • Türkiye
          Edited first message.
          • peste
            • Dec 2016
            • 12710
            • ROMANIA
            post the contents of the bios chip even if it is corrupted..
            • freeelectrony
              • Jun 2025
              • 6
              • Türkiye
              I have already replaced the BIOS chip with a new one with W25Q64FVSIG. I have loaded roms that I downloaded from MSI support in various versions, but they did not work.
              I use CH341A (black) board and neoprogrammer software for writing to chips.
              When I press the power button on the laptop, power goes to the USB ports and the blue LED on the power button and the blue LED on the front start to blink at long intervals, there is no other movement, the screen is always dark.
              There is no battery in the laptop. When I unplug the power plug, hold down the power button and plug it in, the fans first make a small stop-start 1-2 times, then I hold down the power button and the fans start spinning rapidly. After 10-15 seconds, the fans stop and the screen is always dark.
              No matter what I load into the BIOS and EC flash chips, these situations do not change at all.
              It was also tried with an external monitor from the HDMI output, the result is the same.
                • May 2024
                • 97
                • Brasil
                How did you record the (EC KB9028Q) with the (CH341A)?
                • freeelectrony
                  • Jun 2025
                  • 6
                  • Türkiye
                  I write this chip. Not KB9028Q
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                    BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
                  • hyperwood
                    [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                    by hyperwood
                    I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                    The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                    I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                    ✅ What I need:
                    • A working 2MB BIOS dump
                    • Matching NM-E471 Rev. 2.0, e.g. JY575
                    06-25-2025, 02:28 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • hotcrossedbuns999
                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                    by hotcrossedbuns999
                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                    3. I could only locate two chips that look like bios chips. Could someone verify this
                    01-03-2025, 12:32 PM
