[Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
This topic has been answered.
  • m1ch43lzm
    • Mar 2019
    • 1022
    • Peru
    Worth a try cutting the first 0x100000 (1048576 bytes) from the dump posted here, as it seems to repeat over and over
    https://www.badcaps.net/forum/troubl...34#post1511939
    Attached here
    Schematics here: https://www.badcaps.net/forum/troubl...for-schematics
    If the dump doesn't work, you can place your request here: https://www.badcaps.net/forum/troubl...-14are05/page2
    Somebody with the same laptop may do a backup of that chip
    • ekozeko333
      • Jun 2025
      • 19
      • Austria
      Attached here
      I tried the dump, it seems to cycle 20V -0V .. same.
      • ekozeko333
        • Jun 2025
        • 19
        • Austria
        Little update...
        in desparation started to measure every single cap.
        I found a short on this line. I cant trace it to see where it goes, currently I dont have a adjustable power supply or a thermal camera to trace it.
        Does somebody have a idea?
ID:	3679625 Click image for larger version
        • m1ch43lzm
          • Mar 2019
          • 1022
          • Peru
          That's the audio codec, probably some caps between AGND (analog/audio GND) and "regular" GND, both are supposed to be "shorted" somewhere, nothing to worry about
          • ekozeko333
            • Jun 2025
            • 19
            • Austria
            Thanks I was losing my mind last night at 2 AM..
            Then its most likely the PDI Flash that needs to be truly configured.
            somebody with much more experience can tell.
            What I can tell is that I`ve tried To unsoled the TPS and try. I get 5v only.
            With TPS soldered it negotiates to 20V-0V in cycle.
            No shorts found anywhere.
            With the NX20P5090UKAZ​ unsoldered I get 20V constant but it doesnt turn on to pass VBUS --> VINT
            Initially the NX20P5090UKAZ​ was shorted and burned.
            THE SPI Flash was corrupted not shorted ( defect internal ) .
            • m1ch43lzm
              • Mar 2019
              • 1022
              • Peru
              #26
              There's two of those NX20P5090UK, one for each USB-C port, check both
              The TPS65988DJ controls both load switches, it's supposed to receive an "ACK" signal (low) when the switch is conducting
              Datasheet of the NX20P5090 https://www.nxp.com/docs/en/data-sheet/NX20P5090.pdf
              Click image for larger version  Name:	Captura de pantalla 2025-07-11 220547.png Views:	0 Size:	34.0 KB ID:	3680470
              The ACK signals go to GPIO1 and GPIO2 for each port, have to check the Thinkpad L13 Yoga schematics (where the dump I linked came from)
              https://www.badcaps.net/forum/troubl...tic-needed-pls
              On the Thinkpad Yoga L13, GPIO1 and GPIO2 of the TPS65988 have pulldown resistors, on your board (page 31 of the schematics) GPIO1 and GPIO2 have 10K pullup resistors to LDO_3V3 (internal LDO of the TPS65988DJ); so probably it isn't expecting that with its current firmware and causes the "looping"
              But at least with the current firmware it's negotiating 20V with the charger... (with that switch removed from the board)
              GPIO16 and GPIO17 (active low) control the load switches on your board, on the Thinkpad Yoga L13 those GPIOs control some MOSFETs that allow the 20V to pass to VIN; different circuits that basically do the same thing which is to pass the 20V from USB-C to the input of the charge circuit
              Page 41 of the Thinkpad L13 Yoga, and pages 32,35 of your board schematics
              Check the MOSFETs at page 35, PQ13 and PQ17, measure in resistance mode S-D, S-G, D-G
              • ekozeko333
                • Jun 2025
                • 19
                • Austria
                #27
                Thank you for the reply.
                I know there are two of the NX20P5090.
                Ive tested the whole board for short circuits including the PQ13 and PQ17. no shorts there. all is ok.
                Ive did a whole analysis of the PD negotiation uncluding D+ and D- with and without battery on both ports. These are the Pictures attached.
                Summary of PD Negotiation Behavior (based on 4 pictures checked):
                • Port 1 (no battery):
                  VBUS cycles between ~2.3V and 20V (short cycles), current ranges 0.007A – 0.045A.
                • Port 1 (with battery):
                  Longer cycles, VBUS 0V – 20V, current 0.00A – 0.025A.
                • Port 2 (no battery):
                  VBUS cycles ~2.3V – 15V (short cycles), current 0.007A – 0.040A.
                • Port 2 (with battery):
                  Longer cycles, VBUS 0V – 15V, current 0.00A – 0.025A.
                • FNIRSI C1 shows PD cycling through protocols without settling β€” likely due to negotiation failure, proprietary protocols or measurement limits.
                I attached also another working laptops pd negotiation for refrence.
                EDIT: just want to add here that the CURRENT with other FIrmwares was 3A on 5V .. CPU GETTING SUPER HOT.
                Its 90% likely a TPS firmware thing here were talking about. I wish someone could dump the exact same TPS from this exactly same motherboard. and even still I dont know if that is enough or something else needs fixing for the tps to talk to the ECU.
                • ekozeko333
                  • Jun 2025
                  • 19
                  • Austria
                  #28
                  I ordered a cheap logic analyser to attach it to the GPIOS to see whats up. it will take a week or two to report back what happens on these pinouts.
                  This is my first laptop repair and I am learning along the way I might benefit from watching some advanced videos if someone could share something more in depth and tehnical about PD negotiation and signal analysing ?
                  Thank everybody for the feedback and If we fix this I will surely create a indepth tutorial on what happened how to avoid and how to fix it
                  • m1ch43lzm
                    • Mar 2019
                    • 1022
                    • Peru
                    #29
                    I tried to extract the BIOS update from Lenovo dmcn44ww.exe, first with Innoextract, then WinRAR on the WIN64.exe, after that "Majolica.fd" with andyp phoenixtool 2.73; it's the only tool I found that decompiles the Insyde BIOS update .fd into individual modiules, and found 2 interesting files
                    1EAE5997-6A9E-7541-AED4-57FD7BC3BC05_1614.ROM
                    A3187945-5B5E-44C8-B03B-64BAA9E95785_1616.ROM
                    I checked them with hex editor, and the header/structure matches the dump from the L13 Yoga but with some differences
                    Maybe one of them will work for you, both are 45KB, try filling the rest with FF FF .... until you reach 1MB, i'll attach them
                    • dokterpc
                      • Aug 2020
                      • 47
                      • Indonesia
                      #30
                      Attached here
                      Thanks it's work on my latitude 7210 la-j321p, the tps65988 short on 1,8v and i change but stuck in 5V VIN, i try flash the firmware with this and it's work on 20V VIN. Thankss
                      • m1ch43lzm
                        • Mar 2019
                        • 1022
                        • Peru
                        #31
                        That's interesting, a dump from a Lenovo laptop worked on your Dell to get 20V
                        But according to the schematics for the LA-J321P the GPIOs control different stuff: GPIO1 and GPIO2 control a mux that routes the USB2.0 data lines on one of the USB-C ports according to cable orientation
                        Best to get the proper dump for your laptop for full functionality, it may be packaged with the BIOS update or the Thunderbolt controller firmware update
                        https://www.dell.com/support/home/en...-2-in-1-laptop
                        According to your schematics, UT6 is the PD controller flash, UT7 is the thunderbolt controller flash, it depends whether both UT6 and UT7 are fitted on your board
                          • 22084
                          There is a PD update only (not full firmware) in the bios update package
                          • ekozeko333
                            • Jun 2025
                            • 19
                            • Austria
                            #33
                            Sorry for the late update. I was in vacation.
                            YEEEEEEEEEEEEEEEES BABYYYYYYYYY... Youre the best. I knew it. it had to be the Firmware !!!!!!!!!!!!!!!!!!
                            I beg you sir please make a detailed tutorial on how did you find these.
                            I only tried the first one 1EAE5997-6A9E-7541-AED4-57FD7BC3BC05_1614.ROM
                            it worked the first TRY.
                            damn.. after 1 month. I didnt give up on it
                            Thank everyone for supporting me on this journey this was my first FIX . It was a intresting and hard one
                            • m1ch43lzm
                              • Mar 2019
                              • 1022
                              • Peru
                              #34
                              First, unpack the BIOS update dmcn44ww.exe from Lenovo website with innoextract https://constexpr.org/innoextract/
                              You'll get 2 files: WIN64.exe and WIN64.bat, extract WIN64.exe with 7-zip
                              From the extracted contents, you have a file named "Majolica.fd", this is Insyde BIOS update
                              You need andyp's PhoenixTool 2.73, it's on another forum (requires registration, i'll attach here); to decompress it into modules (the PD firmware is not inside the main BIOS 16.384KB, it's on the .fd)
                              Click image for larger version  Name:	phoenixtool.png Views:	0 Size:	26.1 KB ID:	3690758
                              Open Majolica.fd, when it finishes unpacking, there's a folder named DUMP inside phoenixtool folder (don't close Phoenixtool yet, or the DUMP folder will be erased), inside that folder you'll find all the modules that compose the BIOS
                              Now the hard part, is to check every file that's between 30-50KB; i sorted by size and found those two (1EAE... and A318...) that the header matches
                              Code:
                              00000000 00 20 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
                              00001000 00 20 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
                              00001FF0 FF FF FF FF FF FF FF FF FF FF FF FF 00 50 00 00
                              00002000 01 00 E0 AC FE FF FF FF 00 10 00 00 C0 30 00 00
                              There's some minor differences starting at 0x2800
                              Looks like a similar pattern to the dump from the L13 Yoga, that's why I thought: It looks like PD firmware
                              The structure also matches the dump I made from an HP laptop with a TPS65987DDJ (1 USB-C port instead of 2 ports)
                              Now that you've confirmed the 1EAE... file works, I'll also attach here the TPS65988DJ PD controller firmware for this laptop (1MB, padded with zeros), in case someone needs it
                              Yoga Slim 7-14ARE05 Laptop (ideapad) - Type 82A2
                                SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                                This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                                09-12-2024, 03:30 PM
                                SHUTTLE XPC slim DH110 XPC slim i3-7300 Specification for Upgrade or Repair
                                This specification for the SHUTTLE XPC slim DH110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110 boardview and XPC slim DH110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                09-12-2024, 03:28 PM
                                SHUTTLE XPC slim Office DL1000EP XPC slim J4005 Specification for Upgrade or Repair
                                This specification for the SHUTTLE XPC slim Office DL1000EP can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim Office DL1000EP boardview and XPC slim Office DL1000EP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                SHUTTLE XPC slim DH110 XPC slim i5-7400 Specification for Upgrade or Repair
                                SHUTTLE XPC slim DH110 XPC slim i7-7700 Specification for Upgrade or Repair
