[Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
This topic has been answered.
  • ekozeko333
    • Jun 2025
    • 19
    • Austria
    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
    🔥 The Problem Started After Suspected ESD/PD Fault
    I experienced a power issue or ESD event through a USB-C charger
    After that, the NX20P5090 power switch was visibly burned and was replaced
    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
    🧠 What I’ve Done So Far
    Flashed a known-good 16MB "virgin" BIOS (W25Q128JW_1.8V) including DMI regions
    Verified BIOS and EC flash using CH341A (1.8V adapter, verified writes/reads)
    Power rails seem fine; fan and keyboard LED briefly respond
    Still no PD negotiation to 9V/15V/19V, and board does not POST
    ⚠️ Critical Finding – Empty PD SPI Flash
    I found a second SPI flash chip:
    W25Q80DVN1G (1MB, 3.3V)
    Located near USB-C ports and HDMI
    Connected to TPS65988 USB-C PD controller (as confirmed in schematic, see attached)
    💥 I dumped this chip and it is completely empty – all bytes are FF!
    I re-read it multiple times to be sure.
    ❓My Questions
    Why would the PD flash chip (25Q80DV) be totally blank?
    Can ESD or a PD overcurrent event cause this?
    Could a bad BIOS flash or TPS failure erase it?
    Is the TPS65988 dead if it can't boot from SPI?
    Or can it be recovered by flashing the correct firmware to this chip?
    Where can I get a known-good dump (1MB) for this flash?
    Is this blank PD firmware the root cause of stuck 5V PD and no power-up?
    🧾 Summary
    BIOS/EC verified, flashed, still no boot
    TPS65988 likely cannot initialize — its SPI flash is blank
    USB-C stuck at 5V, no 19V negotiation, no battery charging
    Board behavior points to missing PD controller firmware/config
    Need help locating valid firmware or confirming recovery method
    Thanks to everyone in advance for guidance or sharing working dumps. 🙏
  • Answer selected by ekozeko333 at 07-25-2025, 06:01 AM.
    m1ch43lzm
    • Mar 2019
    • 423
    • Peru
    I tried to extract the BIOS update from Lenovo dmcn44ww.exe, first with Innoextract, then WinRAR on the WIN64.exe, after that "Majolica.fd" with andyp phoenixtool 2.73; it's the only tool I found that decompiles the Insyde BIOS update .fd into individual modiules, and found 2 interesting files
    1EAE5997-6A9E-7541-AED4-57FD7BC3BC05_1614.ROM
    A3187945-5B5E-44C8-B03B-64BAA9E95785_1616.ROM
    I checked them with hex editor, and the header/structure matches the dump from the L13 Yoga but with some differences
    Maybe one of them will work for you, both are 45KB, try filling the rest with FF FF .... until you reach 1MB, i'll attach them
      • 20983
      You can request the PD firmware in the bios requests sub forum. You can try one thats posted for a different model and see what happens - https://www.badcaps.net/forum/troubl...34#post1511939
      • Ponto da Manutenção
        • May 2024
        • 97
        • Brasil
        I need more detailed information about your case.
        Equipment serial number?
        Original BIOS backup?
        I didn't quite understand, did you write or record the (EC IT5570VG)?
        I'm posting a (Firmware - ThinkPad USB-C Dock Gen 2 40AS).​​
        • ekozeko333
          • Jun 2025
          • 19
          • Austria
          Model name: 82A2
          Factory ID: CS20
          S/N: LR0E6ZCM
          neither EC IT5570VG I didnt touch it. record or wrote... The initial text was a bit missleading with the EC. I didnt rewrite the EC only the bios and only read the SPI FLASH W25Q80DVSSIG--> it was empty.
          what happened exactly? did the esd wipe out the memory?
            • May 2024
            • 97
            • Brasil
            I do not recommend this recorder model (CH341A)...it is not reliable..
            Here is your repaired file.
            • ekozeko333
              • Jun 2025
              • 19
              • Austria
              I suspect that I cannot write anything to the pd flash (25Q80DV).. it appears to be dead. Likely from the esd damage?
              I tried SPI with Asprogrammer using ch341A.
              Whats much better then the CH341A?
                • May 2024
                • 97
                • Brasil
                I have 4 recorder models, but I recommend these two.
                XGecu T76 USB3.0
                Svod 4
                • ekozeko333
                  • Jun 2025
                  • 19
                  • Austria
                  A little update.
                  the 25Q80DV is DEAD.
                  Ive ordered a new one, comes this saturday.
                  Will try to solder a empty 25Q80DV to the board and let the bios flash it on BOOT TIME. I might get lucky. IF not, then I will need someone to provide me with a working dump from the 25Q80DV.
                  Wish me luck, will report back.
                    • May 2024
                    • 97
                    • Brasil
                    Originally posted by ekozeko333
                    A little update.
                    I posted the file for you to record on (25Q80DV)...
                    • ekozeko333
                      • Jun 2025
                      • 19
                      • Austria
                      The original content size is 1024 for the 25Q80DV ???
                      Panamera_fw_duce2_Ver5_07_007.bin ---> 512kb ?
                      do I flash it from 0x00000000 the 512kb? thats ok?
                        • May 2024
                        • 97
                        • Brasil
                        How do you know for sure that the file is 1mb if it was blank?
                        The file I posted is from the manufacturer Lenovo.
                        "Why would the PD flash chip (25Q80DV) be totally blank?"
                        • ekozeko333
                          • Jun 2025
                          • 19
                          • Austria
                          I am at the edge of tossing the motherboard out...
                          I tried the PD firmware you uplaoded on a new spi flash it flashed OK. soldered it back to the MOBO and soldered the BIOS flash.
                          When I press the power button it goes from 5.1V to 4.8V 3.0A 14.6W. Fluctuates at 2.7-3A.
                          when I hold the power button it goes again to 0.5A and 5.1V.
                          with battery (empty) the power charger flashes 3 times. no negotiation.
                          Measured voltages on the SPI FLASH ok.
                          Tried the factory bios it doesnt even respond to the power button.
                          I can try to replace the TPS65988D. could maybe the firmware be not configured? maybe a new firmware config tool needs to be create with the TPS65981_2_6_7_8 Application Customization 6.1.4 ? and config the I/O pins to match the schematics ?
                          • ekozeko333
                            • Jun 2025
                            • 19
                            • Austria
                            A little update.
                            I played a little with the tool. used the recommended config (didnt config it for my specific BOARD) I tried to see if anything changes and.. .I GOT 20V on plug in... but it is stuck in looping ( cutting the power completly off from the charger and in loop) config is most likely not OK.
                            From this I am confident the only problem I am facing right now is the FIRMWARE for the TPS!!
                              • May 2024
                              • 97
                              • Brasil
                              [CITAÇÃO=ekozeko333; n3669575]
                              Estou prestes a jogar fora a placa-mãe...
                              Eu tentei o firmware PD que você uplaoded em um novo flash spi ele piscou OK. soldou-o de volta para o MOBO e soldou o flash BIOS.
                              Quando pressiono o botão liga / desliga, ele vai de 5.1V para 4.8V 3.0A 14.6W. Flutua em 2,7-3A.
                              quando eu segurar o botão liga / desliga, ele vai novamente para 0.5A e 5.1V.
                              Com a bateria (vazia), o carregador de energia pisca 3 vezes. sem negociação.
                              Tensões medidas no SPI FLASH ok.
                              Tentei o BIOS de fábrica, ele nem responde ao botão liga / desliga.
                              Posso tentar substituir o TPS65988D. talvez o firmware não esteja configurado? talvez uma nova ferramenta de configuração de firmware precise ser criada com o TPS65981_2_6_7_8 Personalização de aplicativos 6.1.4? e configurar os pinos de E/S para corresponder aos esquemas? [/ CITAÇÃO]
                              You can monitor the (TPS65988D) or any other IC with a simple and cheap equipment (logic analyzer)...
                              ​​​​​​​As you found the (NX20P5090) burned, I recommend doing a check on (reverse conduction) initially by (CN7717)...
                              • ekozeko333
                                • Jun 2025
                                • 19
                                • Austria
                                I Think I need a working firmware. there are no shorts anymore.
                                I will craft one today with the tool and looking at schematic closely the I2C talks at 0x23 address. 011b using a 0.9 divider.
                                hopefully this will work. will report back today !
                                  • May 2024
                                  • 97
                                  • Brasil
                                  I know it's not the shortest, but since the IC was toasted...it may have damaged communication lines........for example i2c etc.
                                  • ekozeko333
                                    • Jun 2025
                                    • 19
                                    • Austria
                                    right now I am 99.99% sure its the SPI FLASH firmware problem for the PD TPS control because I played with it and managed to get 20V..
                                    uploaded the Texas Instrument program and the project file so far.
                                    good luck if you try to inspec it.
                                    • ekozeko333
                                      • Jun 2025
                                      • 19
                                      • Austria
                                      For anyone following, tried a new full battery works.
                                      This leaves only the TPS65988DJ to be half defect, no shorts.
                                      Ordered a TPS65988DJ to replace. will follow up
                                        • May 2024
                                        • 97
                                        • Brasil
                                        Excellent ..
                                        • ekozeko333
                                          • Jun 2025
                                          • 19
                                          • Austria
ID:	3679454 Bought a brand new original TPS65988DJ from Mouser.
                                          Replaced it.
                                          Still the same problem.
                                          I wish somebody would drop the firmware config from his TPS flash ... Idk what else could be the problem
                                          made sure the replace was successfull. cleaned pads. applied new solder. etc etc..
                                            SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                                            This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                                            09-12-2024, 03:30 PM
                                            HP Slim Desktop S01-aF0009nf Slim Desktop J5005 Specification for Upgrade or Repair
                                            This specification for the HP Slim Desktop S01-aF0009nf can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0009nf boardview and Slim Desktop S01-aF0009nf schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 03:28 PM
                                            SHUTTLE XPC slim DH110SE XPC slim i5-7600 Specification for Upgrade or Repair
                                            This specification for the SHUTTLE XPC slim DH110SE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110SE boardview and XPC slim DH110SE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            HP Slim Desktop S01-pD0118d Slim Desktop i3-8100 Specification for Upgrade or Repair
                                            This specification for the HP Slim Desktop S01-pD0118d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0118d boardview and Slim Desktop S01-pD0118d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
                                            This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
