NEED BIOS Thinkpad P17 Gen 2
    Hello ,
    NEED BIOS Lenovo Thinkpad P17 Gen 2
    Type 20YV
    PF3Z5XZB
    just the light flashing when plugging in the charger.
    Test without cmos : no fan, no boot, nothing.
    motherboard alone.
    No results.
    charging light present
    Maybe it comes from the bios.
    Do you have any opinions to help me?
    3.18v on Power BTN, which goes to zero when pressed
    3.24v on Bios chip
    Originally posted by Maxpower3 View Post
    Hello ,
    Type 20YV
    motherboard alone.
    No results.
    3.24v on Bios chip
    Become a Badcaps supporter
    Thanks to all supporters.
      Hello ,
      Type 20YV
      motherboard alone.
      No results.
      3.24v on Bios chip
      can you please share the motherboard code or model?
        HP550 / HP750
        NM-D491 Rev: 2.0
        Click image for larger version  Name:	403634812_889091149206811_8563377082582035027_n.jpg Views:	5 Size:	1.88 MB ID:	3163268
        2 chips 25R256 and 25B256
        Ec Nuvoton NPCX997
        It is complicated to take time to repair this type of machine.
        My boss prefers to put this straight in the trash.
        I found the Fl1 and 2 files but
        I don't really know where to cut them i have to compare them when I have the reading.
        U2001 near Ec supplied
          HP550 / HP750
          NM-D491 Rev: 2.0
          Ec Nuvoton NPCX997
          U2001 near CE supplied
          if you are talking about BIOS REGION than delete block 0 TO 320 from top
          Click image for larger version  Name:	image.png Views:	0 Size:	211.3 KB ID:	3163395
          than select offset from 0 TO 1000000 (0 to 1000000 is your new 16mb bios region)
          Click image for larger version  Name:	image.png Views:	0 Size:	174.2 KB ID:	3163396
            Thank you so much
            I created this file with your advice but still the same only LED lights up 3 times when plugging in the charger
            orange light with no battery comsuption 0,07A
            White light with battery same 0.07A
            Battery voltage 11.93
              ok
              try this new one as per your Serial Number PF3Z5XZB Bios version 1.18 and Ec version 1.09 with Clean ME
              • Maxpower3
                Maxpower3 commented
                Editing a comment
                nice, but it's always same.
                nothing and consumption 0.07A.
                there must be another problem.
                no visible damage or liquid traces
              Thank you so much
              Try
              • Maxpower3
                Maxpower3 commented
                Editing a comment
                same but thanks
              Some news
              Solved
              1 filter burn + 1 caps dead
                ThinkPad T14 gen 4
                S/N PF4QME9Z
                Please help change logo to Lenovo one
                Hve try to crate a new tread but don't how to do it
                  I wonder if it's because of the bios. My computer works everything normally, but when I open a large file (for example, an excel file of about 8M), I can't open the file. The cpu temperature is ~ 100 degrees Celsius and the fan is spinning loudly. ,, just close the open file and the computer is normal again, opening small files is normal,, I replaced the hard drive, replaced the ram, installed Windows but it's still the same.
                    Click image for larger version  Name:	dataurl058856.png Views:	0 Size:	359 Bytes ID:	3337373sn:PF-3BPDFZ
                    P17 Gen 2 Laptops (ThinkPad) - Type 20YU
                      Originally posted by lavie View Post
                      ThinkPad T14 gen 4
                      S/N PF4QME9Z
                      Wrong thread.
                        ThinkPad T14 gen 4
                        S/N PF4QME9Z
                        Go to the bios requests start page/index https://www.badcaps.net/forum/troubl...-requests-only , click on the blue "+ New Topic" button
                        Click image for larger version  Name:	Capture.jpg Views:	0 Size:	29.9 KB ID:	3337534
                          Hi all!
                          I have a Lenovo P17 Gen2
                          Type 20YU-003HUS
                          Serial # PF3S0LF3
                          Boot / Setup password was changed and fat-fingered, so now I can't get into the machine.
                          I have an SVOD4 programmer and Software version 0.0.5.9 date 17.03.2025. I managed to read my BIOS, dump it to a file twice and verify, then edit per instructions demonstrated on YT: (https://youtu.be/pEy-XZLU5bA?si=B4sZ6d0MSqqLHNvK).
                          HOWEVER, when I write the edited file and try to boot, I get the POST errors:
                          0271: Check Date and Time settings. (Yeah, that's expected)
                          0251: System CMOS checksum bad - Default configuration used. (Roh-roh...)
                          0177: Bad SVP data. Stop POST task. (GAH!)
                          Configuration changed - Restart the system.
                          The system never restarts - it gets stopped at the Bad SVP data - stop POST message.
                          I re-wrote the original dump back to firmware, and I'm at least booting back to the BIOS/Setup Password prompt, so I know it's got to be my edits. It would help if I knew WTH I am doing, but I'm an idiot.
                          Any help with fixing this file for me would be greatly appreciated. I'm attaching my original dump file, and my edited file for reference. My edits were done in UltraEdit, if that matters.
                          Thanks for any help the Badcaps local Brain Trust can provide!
                          • peste
                            peste commented
                            Editing a comment
                            post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
