Lenovo Ideapad Flex 5 14ABR8 Bios Help.
  • skymoon83
    • Oct 2015
    • 11
    • izmit
    hello. after updating the bios on the lenovo idepad flex5 14abr8 laptop, it is stuck on a black screen. It shines, but there is no image.
    Motherboard code:
    Lc58-abr mb
    223069-2
    448.0re25.0021
    S/N:PW08TQNP
    the original bios is attached. I would be glad if you could help.
    • 22011
    Motherboard code:
    Lc58-abr mb
    223069-2
    448.0re25.0021
    Please Type the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
    • peste
      • 13678
      • ROMANIA
      bios extracted from Lenovo website update for BIOS Update for IdeaPad Flex 5 14ABR8, IdeaPad Flex 5 16ABR8
      DMI 477000 - 4773FF
      KEYWIN 4A4080 - 4A40BF
      • jocecharland
        • Jun 2025
        • 5
        I also have this laptop serial number PW06Y8HK
        I've attached the backup the Lenovo BIOS util made while it borked my laptop
        • peste
          • 13678
          • ROMANIA
          post full name and model, motherboard model, TYPE,etc.
          What can we help you with?...what's your problem???
          • jocecharland
            • Jun 2025
            • 5
            Serial Number PW06Y8HK
            Machine Type Model: 82XX003XCF​
            GTIN: 196803904260
            Motherboard: MB W 82XX WIN R77730U UMA 16G
            Motherboard Part Number 5B21J35232
            The Lenovo BIOS utility corrupted the BIOS chip, system will not boot a device, but I can view/edit BIOS settings booting with Novo. When reading the BIOS chip the corruption seemed to start around 4.1MB.
            If I could get a working image to flash onto the BIOS chip part no W25Q64JW that would be fantastic!
            • peste
              • 13678
              • ROMANIA
              GTIN: 196803904260
              you have everything you need at post #3...
              • jocecharland
                • Jun 2025
                • 5
                Alright, thank you. I copied the given DMI and Windows key bytes from my backup onto the supplied image, but after flashing I'm getting the Caps Lock and Escape keys with an LED, power LED flashes. The only "success" I've have is Caps Lock only being on from flashing my backup, anything else I've tried is both Caps Lock and Escape.
                I'm using a CH341A programmer with the 1.8V adapter, I can flash and verify using ASProgrammer over SPI on IC W25Q128FW_1.8V.
                Any other ideas what I could try? I've spent an incredible amount time on this and at this point I'm at a loss.
                • peste
                  • 13678
                  • ROMANIA
                  The bios chip must be unsoldered from the board before writing or reading..
                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                  solder wires between the programmer and the bios chip..
                  .here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                  • jocecharland
                    • Jun 2025
                    • 5
                    That's a good tip, I'll give that a go. Thanks for the advice!
                    • Loki_Fido
                      • Mar 2025
                      • 127
                      • Japan
                      Here is a fully functional BIOS for
                      Lenovo IdeaPad Flex 5 14/ABR8
                      MFG Date 2023/03/16
                      SN PW05CKVH
                      <<W25Q128FW [1.8V]>>
                      Extracted from booting laptop
                      • jocecharland
                        • Jun 2025
                        • 5
                        MFG Date 2023/03/16
                        SN PW05CKVH
                        Thanks!
                        • Benalimos
                          Benalimos
                          • Dec 2024
                          Is this file for IdeaPad Flex 5 16ABR8 ?
                          • Benalimos
                            Benalimos
                            • Dec 2024
                            DMI 477000 - 4773FF
                            Thanks for the file, but it is not available for download.
                            Please attach a new file
                              • 22011
                              Try it again. Make a good verified backup before you flash any other bios, you will need it to get your DMI from.
                              • jeliecerlara
                                • Apr 2018
                                • 17
                                • Colombia
                                Greetings, could you please help me, I have this BIOS without an image, I have already tried the other posts, and I get the same result.
                                IDEAPAD FLEX 5 14ABR8
                                S/N PW08Y6T9
                                LC58-ABR MB 223069-2
                                448.ORE26.0021
                                • Loki_Fido
                                  • Mar 2025
                                  • 127
                                  • Japan
                                  Try the bios on the post # 11. See if it works.
                                  If it does, let us know, so we can change the win key and serial.
                                    Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Flex 5 14ALC05 boardview and IdeaPad Flex 5 14ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 04:10 AM
                                    Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook 5 Specification for Upgrade or Repair
                                  • mkdj
                                    Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                    by mkdj
                                    Dear all,
                                    I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                    Here the steps I have taken to fix the laptop:
                                    - downloaded latest BIOS from Lenovo Website...
                                    10-18-2025, 03:43 AM
                                    Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                    09-07-2024, 06:38 AM
