Dell G15 5535 (bios needed)
  • Maxwell918
    Rookie
    • Apr 2025
    • 5
    • Venezuela
    Please masters i need your help.. my laptop wont display anything but the keyboard lights turns on, extracted original bios and compared with a random one i made (see below) and saw a lot of missmatch hex data
    Dell G15 5535 (AMD)
    MB: IDO51 LA-M534P Rev 1.0(A00) 2023-02-02
    ST: B9Z5QZ3
    I made one from the dell webpage (BIOS_IMG.rcv v1.9.0) but idk if the one i made its good..Thank you all in advance!
  • LBTT1121
    • Nov 2024
    • 481
    • Việt Nam
    Dell G15 5535 (AMD)
    ST: B9Z5QZ3
    try and feedback
    • Maxwell918
      Rookie
      • Apr 2025
      • 5
      • Venezuela
      Originally posted by LBTT1121
      try and feedback
      Sure! Ill try and let you know, thank you
      • Maxwell918
        Rookie
        • Apr 2025
        • 5
        • Venezuela
        Update:
        Bios successfully flashed but still no display, took a deep look inside the mb and found GPU VCORE is not present 19V VCC is but.. im still beginner so i'll keep looking for a solution thanks for the help
        • 417731
          BIOS needed for Dell Vostro 3405
          by 417731
          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
          Model: Dell Vostro 3405
          Tag:F0B1YF3
          CPU:Ryzen 3500U
          Thanks in advance
          07-06-2025, 06:48 PM
        • re1nhold
          Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
          by re1nhold
          Hello Guys
          I'm currently fixing two different Dell latitudes,
          I need a E5550 BIOS - SERVICE TAG is: FSFB262
          So far I flashed about 6 BIOS from this forum already,
          none worked,
          only fan spin ~3s, LCD black, keyboard LED on/off ok,
          I tried manual extraction with scripts for ages so to speak. VM is untried yet.
          This laptop is not burnt, it seems to just have a corrupted BIOS.
          I extra baught ram. This has to work friends.
          Do you generate it this way in Windows in CMD?:
          Code:
          E5550A24.exe /writeromfile C:\bios.fd
          07-18-2025, 09:18 AM
        • Aarush653
          Dell Latitude 5340 corrupt bios - clean bios needed
          by Aarush653
          Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
          Worked good before failed flash now won't power at all.
          May have been a bad connection.
          Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
          32mb chip - 25Q256JVEN
          Attach Dell Bios Update file v1.14 - original Dell update...
          10-14-2024, 04:28 PM
        • mrrubik
          Dell Optiplex 7010 micro bad BIOS flash?
          by mrrubik
          Hi folks,
          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
          Steps I took:
          1. Read BIOS with CH341a, verified hash twice
          2. Patched
          12-23-2024, 04:11 PM
        • bmxlovah
          Dell Precision T7910 no bios, no post after applying SAS/RAID setup
          by bmxlovah
          My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
          11-24-2022, 06:29 AM
