Lenovo Thinkpad X1 Extreme Gen 4 Wistron 213015-1
  • badcapjerboard
    • Apr 2023
    • 68
    This laptop had a hard fall I was told. I'm not able to read the serial number.
    I would get 3 white lights at the power button when plugged in and then off, but still an orange charge light(most of the time).
    PLC501 gets hot, into the 60s C. It has 1.24v PRC307 is the next hot thing around 40c and PUC301 get's a bit warmer than the other 4 PUs next to it
    PLC301 has resistance to ground of .55ohms but i'm not experienced enough to know if this is normal for such gpus? Voltage on these coils is .75v
    Otherwise i wasn't able to find anything else getting warm even when injecting .7v in the circuits i mentioned.
    One of the ram slot clasps was desoldered from the board which led me to look at the slot pins and some were also loose. I tried resoldering both slots, but behavior was the same afterwards.
    After I noticed pads that looked lke something was broken off at D2601 so i added a diode. After that It would give a solid white power button led, spin fans for a number of seconds, pch and gpu would get warmer than before, but then it never progresses. I've never seen the cpu get warm.
    Can anyone help me figure this out?
    I'm attaching two bios dumps in case anyone is able to check them. Thanks.
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    You must post serial number
    • badcapjerboard
      • Apr 2023
      • 68
      Sorry found it SN: PW020ZLW
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Try
        • badcapjerboard
          • Apr 2023
          • 68
          Thank you. First i got a verify error. Then i lowered clock to 16ghz and got reg error. Lowered more got the same. Click image for larger version
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            Erase chip 2 to 3 time first if still you have an issue change chip
            • badcapjerboard
              • Apr 2023
              • 68
              Not completely sure what's going on. I had issues with new chips also. tried new adapter. Then i found a chip that the programmer ids correctly and it finally programmed successfully. Maybe I need to create a custom chip instead of using a similar id?
              Anyhow, laptop behaved the same with the new file on a different chip. A GD25B256EY
              • badcapjerboard
                • Apr 2023
                • 68
                Mistake. I meant i used a GD25R256EYIG but used id GD25B256EY
                • badcapjerboard
                  • Apr 2023
                  • 68
                  Is there any reason this GD25R256EYIG wouldn't be compatible with original MX77L25650FZ4I42​?
                  Does PLC501 getting so hot mean it's probably a faulty vram chip?
                    Lenovo ThinkPad X1 Extreme Notebook X Specification for Upgrade or Repair
                    This specification for the Lenovo ThinkPad X1 Extreme Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Extreme boardview and X1 Extreme schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                    09-07-2024, 06:31 AM
                    09-07-2024, 05:00 AM
