HP EliteBook 840 14 inch G11 Notebook PC (B05HRUP)
  • trunguntilyou
    • Aug 2022
    • 324
    • Vietnam
    mb: 6050A3510401-MB-A01
    SN : 2MQ4360SD3
    Please unlock bios!!!
  • minhdigital
    • Nov 2022
    • 749
    • Vietnam
    SN : 2MQ4360SD3
    Send to you
    • trunguntilyou
      • Aug 2022
      • 324
      • Vietnam
      Originally posted by minhdigital
      Send to you
      the password is still there
      • minhdigital
        • Nov 2022
        • 749
        • Vietnam
        Upload your backup EC
        • trunguntilyou
          • Aug 2022
          • 324
          • Vietnam
          here is my ec file
          • shiyab
            • Sep 2023
            • 1373
            • india
            SN : 2MQ4360SD3
            try and feedback
              • 20795
              Send to you
              W90 bios region
              • trunguntilyou
                • Aug 2022
                • 324
                • Vietnam
                Originally posted by shiyab
                try and feedback
                this file is unlocked,, thank you everyone for your help
                • minhdigital
                  • Nov 2022
                  • 749
                  • Vietnam
                  here is my ec file
                  Try again !
                  • trunguntilyou
                    • Aug 2022
                    • 324
                    • Vietnam
                    Try again !
                    yesterday I was busy and couldn't respond ,, but shiyab's file the password was lost but I used bcu tool and couldn't save the device's DMI ,, now I will try minhdigital's file and respond later
                    • trunguntilyou
                      • Aug 2022
                      • 324
                      • Vietnam
                      Try again !
                      I tried your file and the situation is exactly the same as shiyab's file, in addition, when entering the bios to change the bios admin password, it still asks for the old password.
                      • Usering
                        • Sep 2024
                        • 47
                        Your password still in io KBC
                        only bypass mpm , not unlock .
                        • trunguntilyou
                          • Aug 2022
                          • 324
                          • Vietnam
                          Oh, I understand, thank you
                          • TauroX
                            • Dec 2024
                            • 16
                            • Ukraine
                            SN 5CG4370NBW
                            Hello everyone. Help me remove the password. I read about similar models and did not find a solution. I tried the same with 845. Nothing happens. It does not even enter the MPM. A full BIOS recovery occurs.
                            • peste
                              peste commented
                              Editing a comment
                              post merged....next time look for a thread with the name and model, motherboard model,of the laptop and post there, if you can't find it, then make a new thread..
                          • TauroX
                            • Dec 2024
                            • 16
                            • Ukraine
                            Originally posted by Sahu ji
                            try this and feedback me
                            Good day. Thank you for answering. The password is still there. I tried to flash the BIOS separately. It does not give a result. Then I put everything back in place. and flashed both the BIOS and the EC at once. There is definitely a result. It gives me this message. When I try to cancel the recovery and reboot, it still asks and does not let me into the BIOS. After another reboot, it still asks for the password.
                            • TauroX
                              • Dec 2024
                              • 16
                              • Ukraine
                              Hello everyone. I've tried a bunch of different options. Up to filling the FF with the entire EC flash, removing it. Replacing regions. Flashing other people's dumps without a password. And so on. But every time the laptop restores everything as if from the factory. I read that this platform has so-called protection against changing the BIOS. Does anyone know where it gets the information from? It's unlikely that the Multicontroller has enough memory to restore everything. And another question. There is a TPM SLB 9672 chip. What if I remove it and start the laptop? I understand that the processor uses it for encryption. Will it be able to work without it?
                              • clrscr
                                • Dec 2020
                                • 184
                                • sing
                                don't has solution unlock ?
                                all donations are welcome,
                                >>>>> click on this link to donate via PayPal. <<<<<
                                • salim1gr
                                  • Oct 2018
                                  • 22
                                  • Sweden
                                  i have hp elitebook 840G11 many try not unlock mpm is unlock but password till there please help i send both file main and ec
                                    SMDFlea commented
                                    Editing a comment
                                    Serial number ?
                                • salim1gr
                                  • Oct 2018
                                  • 22
                                  • Sweden
                                  5CG428277B SERAL hp 840G11
                                  • munir100
                                    • Dec 2018
                                    • 178
                                    • uae
                                    try and give reply
                                      HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-07-2024, 05:50 AM
                                      HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-07-2024, 05:20 AM
                                      HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
