HP ENVY X360 13-AY Ryzen7 5800U board LA-J482P M76378-601/ M76376-601 BIOS
  • jaroslav.psenicka
    • Jul 2020
    • 34
    • Czechia
    I have a HP ENVY X360 13-AY Ryzen7 5800U computer here
    • shows 5 long, 3 short capslock flashes when the WIN+B is pressed
    • turns itsef off after 2-3 secs otherwise
    based on the 5+3 flash code, I believe it's a BIOS issue
    so I wonder if some of you guys have the LA-J482P BIOS on hand
    thanks,
    -jp
    • 20995
    Post your backup and the laptop serial number - Read: https://www.badcaps.net/forum/troubl...before-posting
    • jaroslav.psenicka
      • Jul 2020
      • 34
      • Czechia
      Thanks SMDFlea,
      here are details I was able to find
      • HP ENVY x360 Convertible
      • Model 13-ay1003nc
      • ProdID 58W53EA#BCM
      • SN# CND1442RZ4
      I am having difficulties reading the BIOS chip GD25LB128DSIG, my EZP2010 reader can't detect nor read it when manually configured as GD25Q128.
      It's 1.8V chip, I am using the low voltage adapter.
      The laptop can't read the chip as well IMHO, so it might be dead or unreadable.
      So I wonder if there is a chance to get a binary and flash it into a new chip.
      Regards,
      -jp
        • 20995
        Change the programmer speed to 6MHz and try again. If that doesn`t work buy a CH341A and try it with that.
        • jaroslav.psenicka
          • Jul 2020
          • 34
          • Czechia
          Hi SMDFlea,
          finally, the 1.8V adapter was faulty
          plase find the bios dump attached
          can you verify the file? it might be corrupted
          thanks,
          -jp
          • LBTT1121
            • Nov 2024
            • 554
            • Việt Nam
            Hi SMDFlea,
            thanks,
            -jp
            Hi, Try and feedback
            • HaiPa
              • Oct 2021
              • 42
              Hi guys,
              I do have the same board in a Hp Envy 13-ay1013na, Ryzen 7 5800u
              I only get the laptop to power for about 3-4 seconds with no caps code flashing, no fan spinning it just goes off.
              My first guess was that is a bios related problem, as the laptop gets power, it does charge the battery.
              Motherboard : la-j482p rev.1 SPS M76379-601.
              I did try to flash the dump attached previously with no success and it dues the same thing.
              Could someone check my bios or have a fresh one? thanks
              Edit SN:CND14816LW going by the bottom cover
              • peste
                • 12859
                • ROMANIA
                Originally posted by HaiPa
                Hi guys,
                bios extracted from HP website update for HP ENVY x360 Convert 13-ay1013na (5R5T3EA)
                DMI + KEYWIN B1000 - B203F​
                • HaiPa
                  • Oct 2021
                  • 42
                  Thanks very much for the reply and your time peste, Just finished writing the bios but it might be a total different issue as it has the same symptoms as before.
                  Ms colegu
                  • peste
                    • 12859
                    • ROMANIA
                    Ms colegu
                    Maybe the laptop has another problem.
                    • jaroslav.psenicka
                      • Jul 2020
                      • 34
                      • Czechia
                      thanks LBTT1121 ,
                      I managed to wrte the bios data, unfortunately it did not help
                      I'll try to flash the version I extracted from the sp155608.exe (downloaded from https://support.hp.com/gb-en/drivers...-pc/2100744992)
                      the exact product code is 13-ay1003nc, the 13-ay1000 is the closest version I have
                      compared to both my old and your version, this is different
                      will keep you posted
                      thank you for the help,​
                      -jp
                        • 20995
                        thanks LBTT1121 ,
                        -jp
                        Post 8 is the right bios BID08929. If that one doesn`t work look for a hardware problem. The 5:3 error is sometimes loose ram slot pins, cracked solder balls under the SOC.
                        • dahnking
                          • Apr 2018
                          • 258
                          • kenya
                          working confirmed
                          • CHERIF
                            • Jan 2021
                            • 16
                            • Mali
                            it's well working this file
                              HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                              09-06-2024, 12:18 PM
                              HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-06-2024, 11:17 AM
                              HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                              HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 06:51 AM
                              HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                              This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                              09-06-2024, 06:50 AM
