Lenovo P15s Gen 2 - Absolute Removal
This topic has been answered.
  • ShockStruck
    • Dec 2024
    • 13
    Hello!
    I was hoping one of you kind folks could assist with removing Absolute on the attached bios dump? There is no password on the bios, so I am hoping this can be done without replacing the MEC1503 with one from a donor board.
    Model: Lenovo P15s Gen 2 (20W7-S1KR00)
    Serial: PF3CV07L
    Board: NM-D352 rev 1.0
    Fixed attachment
  • Answer selected by ShockStruck at 12-26-2024, 05:43 PM.
    volinakis
    • Jan 2021
    • 2728
    • N/A
    Originally posted by ShockStruck
    Great news! I was able to grab a few matching dumps of U2201 successfully!
    Please see attached.
    try
    • volinakis
      • Jan 2021
      • 2728
      • N/A
      Hello!
      Serial: PF3CV07L
      upload again your bios backup, it can't be downloaded
      • ShockStruck
        • Dec 2024
        • 13
        Ahhh sorry about that, I have attached it here.
        • volinakis
          • Jan 2021
          • 2728
          • N/A
          read again mx25l25673g, it has errors. If you use CH341 read 3-4 times and compare results, when you have 2 identical it means you have a good backup.
          • ShockStruck
            • Dec 2024
            • 13
            Okay, I am reading the chip right now. Will reply back after 4 dumps that much.
            • ShockStruck
              • Dec 2024
              • 13
              Alright, so I have just completed another 4 reads of the chip in question with the program "AsProgrammer". These all have a matching MD5 hash so this SHOULD be a solid dump.
              • volinakis
                • Jan 2021
                • 2728
                • N/A
                there are 2 chipsets, U2201 and U2202, U2201 is main bios, I think you read U2202.
                • ShockStruck
                  • Dec 2024
                  • 13
                  You thought correct, I have been reading U2202. U2201 appears to be a Winbond 25R256JVEN which may be difficult to get my clip around. I'll give it a try but if I end up needing to bust out the soldering tools this may need to wait until tomorrow.
                  Either way, I very much appreciate your assistance and patience.
                    • 20807
                    Is U2201 a WSON chip and your clip is SOP8 ? , if so don`t even try to use that clip you`ll damage the chip.
                    • ShockStruck
                      • Dec 2024
                      • 13
                      It appears to be so, any suggestions on how I should go about reading this chip? I was thinking about trying some female to male dupont wire to use as probes, but ultimately I'll likely need to either solder wires to the legs, or obtain a WSON8 clip probe for an accurate read.
                      • Stefan Steff
                        • Mar 2024
                        • 246
                        If you can't desolder the chip and read it with a WSON to DIL8 adapter I think the best solution for your case will be to solder wires to the 8 pins of the chip...
                        Good Luck!
                        • ShockStruck
                          • Dec 2024
                          • 13
                          Good Luck!
                          Thank you kindly for the advice! I went ahead and bought a WSON8 probe with long flexible legs I will try first (really trying to avoid applying any heat to the board if not totally necessary). If that doesn't work, I will try soldering small wires to the 8 pins of the chip.
                          • ShockStruck
                            • Dec 2024
                            • 13
                            • volinakis
                              • Jan 2021
                              • 2728
                              • N/A
                              try
                              • ShockStruck
                                • Dec 2024
                                • 13
                                try
                                Thank you kindly! I was able to flash this and disable Absolute permanently in the BIOS. It did give me a "restoring bios from backup" and "bad crc of security settings in EFI variable" a few times but that appears to have went away.
                                ​​​​​​After restoring BIOS to default and making some changes, it did power off and give me the power button triple light blink. I'm thinking this may just be a dead battery though? I'll let it charge and see what happens.
                                • volinakis
                                  • Jan 2021
                                  • 2728
                                  • N/A
                                  usually "power button triple light blink" happens when you plug in the charger
                                  • ShockStruck
                                    • Dec 2024
                                    • 13
                                    I should also say the laptop is now refusing to turn on alongside that. I'm hoping it's not some weird interaction of the modifications + some of the settings I enabled in the BIOS.
                                    I'll let it charge and then if it still doesn't power on, pull main battery/CMOS battery. A BIOS update is probably good measure too I'd imagine.
                                    • ShockStruck
                                      • Dec 2024
                                      • 13
                                      Just wanted to follow up and say I've worked out all the kinks and am eternally grateful for all the help you and this community has offered me.
                                      Happy Holidays!
                                        Lenovo ThinkPad P15s Mobile workstation P Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad P15s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P15s boardview and P15s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-07-2024, 06:38 AM
                                        Lenovo ThinkPad P15s Gen.2 Notebook P Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad P15s Gen.2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P15s Gen.2 boardview and P15s Gen.2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                        09-07-2024, 05:20 AM
                                        Lenovo ThinkPad P15s Gen 2 Notebook P Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad P15s Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P15s Gen 2 boardview and P15s Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                        Lenovo TS/NB WS P15s G2 I7 16G 512G LNX Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo TS/NB WS P15s G2 I7 16G 512G LNX Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TS/NB WS P15s G2 I7 16G 512G LNX boardview and TS/NB WS P15s G2 I7 16G 512G LNX schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
