I have 1 day to fix 25Q64FW & 25B64C, please help thx
  • chris89
    • Jan 2015
    • 69
    • United states
    They won't erase or write at all, the 25B64C needs to disable write protection, so I can flash modded bios.
    Need help. Thanks
Name:	Screenshot 2024-08-27 140557.png
Name:	Screenshot 2024-08-27 141041.png
  • ahmedtou
    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
    by ahmedtou
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next
    08-27-2025, 08:49 AM
  • testaccgta
    Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
    by testaccgta
    Hi, everyone!
    I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
    I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
    09-01-2024, 08:24 PM
  • hasel17
    CH341a can erase and read but can't write and blank check
    by hasel17
    So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
    Code:
    Checking for blank...
    (Press
    10-26-2023, 06:20 AM
  • ChaosLegionnaire
    bug of the month: write caching setting for the hard drive in device manager
    by ChaosLegionnaire
    i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
    so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
    10-06-2019, 01:39 PM
  • EbrahimSiami
    Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
    by EbrahimSiami
    I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
    **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
    **What I have tried so far:**
    1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
    07-02-2025, 02:31 PM
