Flashing HP Elitebook x360 1030 g2 with EZP2023+
  • Souricier
    • Aug 2024
    • 24
    • France
    The model is HP Elitebook x360 1030 g2
    S/N is 5CG7342PY8
    6043B0211511 Rev A01 could be the mothercard model
    I have succeeded removing the Winband W25Q128JV from the MotherCard => should I also remove W25Q64JV ?
    When I am reading the 128 with EZP2023+ it's telling me it's ATMEL 93_EEPROM AT93C46@16 ...
    Is this program reader able to detect this chip ?
    I have used a adaptor from SOP8/16 to DIP8 (150m) : is that correct ?
    Thank you for your help
  • Souricier
    • Aug 2024
    • 24
    • France
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      S/N is 5CG7342PY8
      you need to tell the programmer the correct chip and post the backup bin
      • Souricier
        • Aug 2024
        • 24
        • France
        I have manually selected chip with below carateristics :
        Type = SPI_FLASH
        Manufacturer = WINBOND
        Name = W25Q128JV
        Size = 16MB
        Pagesize = 256
        And I read it at 12MHz and 6MHz.
        But what I got is an empty bin I guess (renamed .txt)
        • dnytwaryors
          • Aug 2023
          • 54
          • Philippines
          Type = SPI_FLASH
          Name = W25Q128JV
          Size = 16MB
          Pagesize = 256
          Use CH341A Programmer Green with volt controller.
          • Souricier
            • Aug 2024
            • 24
            • France
            I am using EZP2023+ with voltage adapter.
            If the chip is blank, is it possible to flash it with a bin file ? Is it possible to buy a new chip and flash it with a bin provided by someone on this forum ?
            The trick is that I don't have access neither to Windows ...
              • 22191
              EDIT: Try it without the voltage adapter, the chip is 3.3V
              Its important to make a good backup of the chip, or you create more work and more problems later on.I would take the advice given already,and buy a CH341A. They are very cheap,and better than the EZP programmers if you use it with alternative software
              • Souricier
                • Aug 2024
                • 24
                • France
                I will follow your advice and order a CH341A with 1.8 adapter. What are the alternative software and where can they be found ?
                I have tried so many combinations that I don't even know if my chip is still good. If not, am I condamned ?
                  SMDFlea commented
                  Editing a comment
                  Try the EZP without the voltage adapter, the chip is 3.3V ,i just noticed that you are using the voltage adapter in post 6
              • Souricier
                • Aug 2024
                • 24
                • France
                I will but with the EZP2023+, is my adapter's correct (see attached picture) ?
                In what position should the chip be in the adapter (there 4 possible positions) ?
                • Souricier
                  • Aug 2024
                  • 24
                  • France
                  I have tried with CH341A (Black) but can't read the chip
                    • 22191
                    Use NeoProgrammer software with the CH341A
                    • Souricier
                      • Aug 2024
                      • 24
                      • France
                      I am using Neoprogrammer 2.2.0.10 with no voltage adapter.
                      My question is how should the chip adapter should be plugged in the CH341A (I think in the lower part but what position ?).
                      Same question for the chip on the adapter : should it be with the black side upper or lower ?
                        • 22191
                        You can find a link to a CH341A programming guide at the winraid forum --> 1.1.1.6. CH341A https://www.badcaps.net/forum/troubl...21#post1622421
                        • Souricier
                          • Aug 2024
                          • 24
                          • France
                          The guide has no images (all missing) so it's not helping very much :-(
                            • 22191
                            Are you sure,there`s lots of pictures when i visit the site
                            • Souricier
                              • Aug 2024
                              • 24
                              • France
                              Click image for larger version  Name:	Guide.jpg Views:	0 Size:	56.0 KB ID:	3330599
                              That's the link I visited but all I get is :
                                • 22191
                                Try a different browser
                                • Souricier
                                  • Aug 2024
                                  • 24
                                  • France
                                  I was using Opera, I've just installed Firefox but same result.
                                  If you're tlaking bout this link : https://winraid.level1techs.com/t/gu...pictures/33041 I am not in this situation.
                                  I had a soldered chip that I took off from the motherboard, so I can't use the clip. I'm just asking how to put my chip in the adapter (the black side up or down) ?
                                    • 22191
                                    https://winraid.level1techs.com/t/gu...rammer/32948/3
                                    • Souricier
                                      • Aug 2024
                                      • 24
                                      • France
                                      I have respected all what you kindly send to me but the only thing I got is :
                                      Is it possible to buy a new chip a start from scratch ?
                                        SMDFlea commented
                                        Editing a comment
                                        If the chip is dead its dead. Yes,buy another one.
                                      HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                      09-06-2024, 08:27 AM
                                      HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-06-2024, 06:40 AM
                                      09-06-2024, 05:33 AM
                                      HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                      09-06-2024, 11:32 AM
