Fujitsu HF3M0 NM-D381 rev 3.0
  • trunguntilyou
    • Aug 2022
    • 328
    • Vietnam
    The original bios has no image source,, try another bios that has an image but does not recognize the hard drive
    serial no. R2300185
    product :FPC02581LK
    model: 9C13A1
  • minhdigital
    • Nov 2022
    • 757
    • Vietnam
    serial no. R2300185
    product :FPC02581LK
    model: 9C13A1
    Send to you
    • trunguntilyou
      • Aug 2022
      • 328
      • Vietnam
      Originally posted by minhdigital
      Send to you
      works perfectly ! Thank you comrade
      • trunguntilyou
        • Aug 2022
        • 328
        • Vietnam
        Send to you
        Sorry, currently the computer is booted into Windows normally, but in the bios the computer configuration is lost and in the bios it recognizes the mouse but in Windows it doesn't recognize the mouse and there are many drivers with yellow exclamation marks, I have tried to update driver but it doesn't work
        • minhdigital
          • Nov 2022
          • 757
          • Vietnam
          Try again !!
          • trunguntilyou
            • Aug 2022
            • 328
            • Vietnam
            Try again !!
            everything works!,,, thank you for your support
            • Focus2005
              HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
              by Focus2005
              Hello everyone.
              I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
              05-01-2025, 05:41 AM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • Loki_Fido
              Merge Fujitsu Esprimo WD 1/X FMVWXD1 BIOS please
              by Loki_Fido
              Hi ya folks,
              I have a corrupted BIOS on a Fujitsu Esprimo WD 1X FMVWXD1.
              I have downloaded the bios from the Fujitsu website. But im having trouble merging the files.
              Any kind hearted soul's out there willing to help?
              Make Fujitsu
              Model Name Esprimo WD 1/X
              Model Number FMVWXD1
              Serial Number MA6400008
              Motherboard markings W26361-W4002-X-03 W26361-W4002-Z104-36
              CP709321-02
              I tried to merge. But the BIOS from their website is bigger than the bios from the computer.
              Any help is appre...
              06-16-2025, 02:32 AM
              by Vesko356
              08-11-2023, 03:27 AM
            • grimacelord
              Latitude E6530 - Trouble Extracting BIOS Image From EXE
              by grimacelord
              Hi folks,
              I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
              Service tag number for this model is: "JYDWYW1".
              Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
              I have tried:
              • Simply extracting with 7zip
              • PFSExtractor
              • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
              • Check Temp folder
              10-26-2023, 08:15 AM
