HP 6050A3161901-MB-01 - Endpoint Security Controller - MPM Request
  • evolutiontech
    • Oct 2019
    • 14
    • Chiaravalle
    Hi to everyone , i've got an HP with faulty EC Firmware that replaced together with BIOS chip. i taken the backups of a working machine (I've 20 similar pc's to repair) and after i flash EC Firmware (16MB) and BIOS Bin (32MB) the pc boots but it gave me "There is a problem with the Endpoint Security Controller on this device" probably because of a mismatching between old backups DMI. I would like an help to unlock MPM mode in order to rewrite manually all the new data.
    I Attach BIOS and EC file hoping for an help .​
    • 22146
    Please read the rules,there`s a sticky thread at the top of the bios requests. Post the full laptop model and serial number
    • kolebbk
      HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
      by kolebbk
      Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
      HP Endpoint Security Controller problem
      there is a problem with the hp endpoint security controller on the unit
      I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
      09-04-2024, 12:44 AM
    • fede77
      Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
      by fede77
      Notebook HP ProBook 450 G8
      ProdID 2K8L1LT#AC8
      Mother: DAX8QAMB8D0 REV D
      The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
      03-10-2025, 07:12 AM
    • tech_guru
      HP Elitebook 840 G8 Endpoint security controller issue
      by tech_guru
      Hello!
      I have a laptop HP ELITEBOOK 840 G8 with bios admin password which I wanted to remove by programming the ec chip on the bottom of the motherboard. I read the file with RT809 and put FFs in hex from the first NvramActiveRegn until the next many FFs in the hex. Flashed it back, bios pass got removed but now I have another error at post: There is a problem with the hp endpoint security controller on the unit.
      Any ideas? Please find attached the files (original bios+ec and the unlocked ec file)...
      09-19-2025, 09:13 AM
    • lamonde
      850 G6 Endpoint Security Controller Problem
      by lamonde
      Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
      and there is no soud after flashing new bios, may be have some solutions?
      ProdID: 4YD62AV
      SN: 2TK9500V8X...
      01-15-2025, 09:31 AM
    • biednybelfer
      HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
      by biednybelfer
      After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
      Mainbard model:6050A3044201-MB-A01 (A1)​
      Serial Number: 5CG0275ZLV
      (I'm not allowed to upload files with the extension bin, so I upload zip)...
      10-05-2024, 05:04 AM
