HP Elitebook 840 G8 Endpoint security controller issue
  • tech_guru
    • Nov 2018
    • 44
    • Greece
    Hello!
    I have a laptop HP ELITEBOOK 840 G8 with bios admin password which I wanted to remove by programming the ec chip on the bottom of the motherboard. I read the file with RT809 and put FFs in hex from the first NvramActiveRegn until the next many FFs in the hex. Flashed it back, bios pass got removed but now I have another error at post: There is a problem with the hp endpoint security controller on the unit.
    Any ideas? Please find attached the files (original bios+ec and the unlocked ec file)
  • noname2024
    • Aug 2024
    • 295
    • CỎ MỸ XỊN
    fix
    • tech_guru
      • Nov 2018
      • 44
      • Greece
      Originally posted by noname2024
      fix
      Hi and thanks you for the file. Is this only for the BIOS chip?
      So both chips need programming after all to remove the admin pass? Or bios admin and hp endpoint are 2 different things?
      • Nene01
        HP Elitebook 830 G8 HP Endpoint Controller error and no power issue (intermitent)
        by Nene01
        I have a HP Elitebook 830 G8 with endpoint controller error and besides that laptop sometimes doesn´t power on and i think it´s bios related also.
        I already tried to solve the issue with SMDFlea patch fix and now i can´t power on the equipment anymore not even replacing main bios by its original.
        Please take a look at my original main bios and help me if possible (i also attached EC BIOS without password).
        The mainboard also had password that i manage to remove.
        Best Regards...
        01-11-2025, 01:09 PM
      • filewalker
        HP Elitebook 840 G5 Endpoint Security Controller Problem
        by filewalker
        I have recently bought a Laptop that has a Endpoint Security Controller Problem. According to the seller it has just appeared all of the sudden.
        Things I have tried so far:
        • Restore the security settings to defaults and restart the laptop
        • Disable all the security options
        • Clear the NvramActiveRegn areas (replace with FF) Hex Area 37000-38FF0
        Also I have checked the DMI Information which seems right according to the stickers on the mainboard.
        Is there anything else I can try?...
        10-27-2022, 02:52 AM
      • fede77
        Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
        by fede77
        Notebook HP ProBook 450 G8
        ProdID 2K8L1LT#AC8
        Mother: DAX8QAMB8D0 REV D
        The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
        03-10-2025, 07:12 AM
      • lamonde
        850 G6 Endpoint Security Controller Problem
        by lamonde
        Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
        and there is no soud after flashing new bios, may be have some solutions?
        ProdID: 4YD62AV
        SN: 2TK9500V8X...
        01-15-2025, 09:31 AM
      • biednybelfer
        HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
        by biednybelfer
        After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
        Mainbard model:6050A3044201-MB-A01 (A1)​
        Serial Number: 5CG0275ZLV
        (I'm not allowed to upload files with the extension bin, so I upload zip)...
        10-05-2024, 05:04 AM
