HP Elitebook 650 G10
  • Dallen Bryce
    • May 2024
    • 13
    Hello, I'm trying to remove the password from an HP Elitebook 650 G10. It's motherboard has two chips, a 32mb spi (W25Q256JVEN) and 32mb ec (GD25B256EYIG). I have created a dump of each, but don't know which one(s) to patch. Could someone point me in the right direction or just patch it for me?
  • rex98
    • Feb 2023
    • 1235
    • Mandaue CEBU, Philippines
    serial number?
    • Dallen Bryce
      • May 2024
      • 13
      Originally posted by rex98
      serial number?
      SN: 5CD337MNLH
      Let me know if there is any further required information.​
      • rex98
        • Feb 2023
        • 1235
        SN: 5CD337MNLH
        Only flash this main do not touch the EC.
        first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
        use BCU. you can permanently disable Absolute lock in BCU.
        here's your DMI:
        Serial Number: 5CD337MNLH
        Product #/SKU: 7Z5F2UT#ABA
        CT Number: PRVPA068JIK0H2
        Description: HP EliteBook 650 15.6 inch G
        BuildID: 23WWKRBZ602#SABA#DABA
        Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbhcAfPgSguhKjhk8mEmGn7nVpDpTpnpppqprqMqz.R4
        MAC Address : E4:0D:36:09:18:CA​
        • Dallen Bryce
          • May 2024
          • 13
          here's your DMI:
          Flashed to main, now computer doesn't turn on. Just a flashing white/yellow power led and solid numlock led. How to progress?
          • rex98
            • Feb 2023
            • 1235
            check solder. flash your original dump see if it boots.
            • Dallen Bryce
              • May 2024
              • 13
              here's your DMI:
              Excellent! Now I'm getting the MPM error on booting with a countdown, is the info you put supposed to help remove that? Please tell me how to apply it.
              • rex98
                • Feb 2023
                • 1235
                make sure you follow my instructions at first boot..
                goto bios set machine unique data put that DMI i sent and restart a few times to get rid of the mpm mode. or goto youtube university search how to use BCU
                • Dallen Bryce
                  • May 2024
                  • 13
                  I successfully filled out all the information except for the mac address. Now the internet doesn't work on windows. I'm getting 'Access Denied' when trying to unlock mpm through bcu. How can I set the mac address without reflashing?
                  • rex98
                    • Feb 2023
                    • 1235
                    its optional to fill the mac address. make sure you have drivers.
                    • Dallen Bryce
                      • May 2024
                      • 13
                      Yep, I have drivers, but the wifi device fails to start (code 10 in windows). Resetting the device shows error 43. Booting into a live linux distro shows a bunch of errors about the wifi card.
                      By the way, would it be safe to reflash the bios with the same patched bin you sent?
                      • Dallen Bryce
                        • May 2024
                        • 13
                        Here is a list of the network interfaces on the computer. Should there be a mismatch between them? I really want to get this fixed.
                        Code:
                        Description:    Intel(R) Ethernet Connection (16) I219-V
                        Physical address (MAC):    64:4e:d7:ac:91:5a
                        Status:    Not operational
                        Maximum transmission unit:    1500
                        Connectivity (IPv4/IPv6):    Disconnected
                        Description:    Intel(R) Wi-Fi 6E AX211 160MHz
                        Physical address (MAC):    e4:0d:36:09:18:ca
                        Maximum transmission unit:    0
                        Name:    Local Area Connection* 9
                        Description:    Microsoft Wi-Fi Direct Virtual Adapter
                        Physical address (MAC):    e4:0d:36:09:18:cb
                        Status:    Not Present
                        Proxy Auto Detect:    On
                        • rex98
                          • Feb 2023
                          • 1235
                          YES flash it again. after following my instructions about the reset settings. flash your original dump main and it will be okay. password will be gone
                          • Dallen Bryce
                            • May 2024
                            • 13
                            Reflashed, same problem. Could this be an intel me problem? I'm out of options and don't know what to do.
                            • miansh621
                              Banned
                              • May 2022
                              • 133
                              • pakistan
                              motherboard code
                              • Dallen Bryce
                                • May 2024
                                • 13
                                Originally posted by miansh621
                                motherboard code
                                Under the ram it shows
                                HSN-Q32C-4MB
                                MODEL:X8T
                                DAX8TMB8E1 like this
                                HSNQ32C4MB ?
                                • JanBono
                                  • Sep 2024
                                  • 4
                                  • France
                                  Hello, I've a similar problem with my HP Elitebook 650 G10 recently bought. W10 Pro64 is well installed, up to date, HP drivers updated through HP support site including BIOS update, and I could even make a W11 upgrade...but I cannot access the BIOS as I've not the BIOS password.
                                  I see that rex98, a badcaps veteran 👍 , may be in position to give some recommendations on the way to reinitiate password in a software way.
                                  If this is feasible, what have I to do for reflashing the BIOS?
                                  Here are some info:
                                  Product Numbers: 917G0EC#ABF
                                  Serial Number: 5CD3439CB8
                                  I see that some of you made "dumps" for getting more useful information? How did you proceed?
                                  Thanks for any relevant advice 😊. Best
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11179
                                    • Viet Nam
                                    Here are some info:
                                    You have to learn how to use a programmer, the cheapest one is the CH341A.
                                    https://www.youtube.com/watch?v=Ta_PPndnCTk&t=447s
                                    • JanBono
                                      • Sep 2024
                                      • 4
                                      • France
                                      hoaca388, thank you for the tip!
                                      Nevertheless, I'm a newbee on the domain. Is there a end-to-end process somewher on the forum to guide me on the steps?
                                      I understand the steps:
                                      Find a CH341A with motherboard connectot and the gets the associated soft (AsProgrammer?)
                                      Identify which cheap to connect on the Motherboard
                                      Make the extraction/dump
                                      Then How do I program it in hexa for suppressing the password?
                                      Anyway, thanks for your support.
                                      No urgency as my PC is working well with W10 and even can be upgrade in W11. I just would be happy to control it if a BIOS change is needed.
                                      Best
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11179
                                        • Viet Nam
                                        Best
                                        The fist read : https://www.badcaps.net/forum/troubl...rces-and-tools
                                        The software (Asrogrammer,.....) is free.
                                        Post your locked bios here, someone will unlock it for you.
                                          HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:50 AM
                                          HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:20 AM
